11-13-2014, 08:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | how to write pit file with octopus i download the firmware of s5830i from support section now what thing i have to tick for write pit file also beacuse the restat problem only fix with pit file |
11-13-2014, 09:39 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. You can use firmwares which are already have PIT file inside. Such firmwares has "PIT" prefix in title. There are 2 firmwares with PIT for GT-S5830I available in Support Area. |
11-14-2014, 16:00 | #3 (permalink) | |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Quote:
but their is a pit file if i first wirte pit file PIT-GT-N7100.pit then after write N7100XXUFND3_N7100ODDFND2_INU_India_Android_4.4.2. oct then is method is safe or not pls tell me dear team | |
11-14-2014, 16:16 | #5 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
11-14-2014, 17:49 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Do the next: 1. Run the Software. 2. Press "Go to Support" button at "Support & Options" tab in the Software. 3. Search the firmware "PIT_N7100XXUFND3_N7100ODDFND2_INU_India_Android_4 .4.2.oct" in the folder "Samsung/GT-N7100/". 4. Download the firmware. |
11-15-2014, 09:46 | #8 (permalink) | |
Please put the phone into Download Mode and connect USB cable. To put GT-N7100 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Snapshot_2014-11-15_141250 - Download - 4shared - diesel kumar pls help me sir | |
11-15-2014, 13:36 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Disable "Manual Select" and "Skip BOOT area write" options in Software and repeat "Write Firmware" operation. If problem remains the same - try to write "PIT_N7100XXUFND3_N7100ODDFND2_INU_Android_4.4.2.o ct" firmware from the Support Area. |
03-09-2018, 17:03 | #10 (permalink) |
Freak Poster Join Date: Jan 2017 Location: Lahore Age: 29
Member: 2675538 Status: Offline Thanks Meter: 90 | an error has occurred while updating the device software use the emergency recovery function j510f hwo ti can fix with octopus smart switch not fount this model |
