07-26-2013, 14:08 | #1 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | I can not flash C3313T I can not flash C3313T, starts and stops the process. As I can do to unlock this phone? Thanks in advance. Quote:
07-26-2013, 17:27 | #3 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Battery fully charged, still the same error. Another suggestion? Try for UART, same error. Thank you. Quote:
07-29-2013, 13:38 | #6 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Octopus does not unlock this model, FlashTool_E2_XMM2150 flash and then try to unlock, did not come out, use C3312 model also without results. I solved with another tool. Something is not right in these models. regards mfeliu07 Quote:
07-29-2013, 13:43 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | What software version do You use? Please use the latest (http://octopusbox.com/files/softs/in...sung_1.2.6.exe) and post here full software log. |
07-29-2013, 14:52 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Now write firmware with this software version and post screenshot and logs with Write firmware and Read codes procedures. |
09-21-2013, 01:08 | #11 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Cuba
Member: 1202427 Status: Offline Sonork: 100.1604781 Thanks Meter: 27 | Hello, though this post is almost dropped, I am going to retake it. And report that Octopus Samsung 1.3.3 still do not flash this model, either via USB or UART. It terminates the process almost after it starts, with an error. I downloaded octopus firmware version .oct and of course, I can not use this flash file with other software. Also, the original firmware is not available on the net. At least, I have not being able to find it using google. Since this model has to be flashed with firmware from support, which is the solution for flashing failure? Best regards. |
09-23-2013, 07:04 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ zeddicus Hello. Please conmtact us, we will look remotely where can be the problem with your phone with writing firmware. |
09-25-2013, 01:57 | #13 (permalink) | ||
Member: 1202427 Status: Offline Sonork: 100.1604781 Thanks Meter: 27 | Quote:
I can provide you logs, precise feedback and anything else, but you will not be able to connect remotely. Now, I am sure it is not a phone problem, because I have tried with different phones C3313T from different clients and Octopus Samsung always fails to flash the firmware. The thing is that it connects with the phone in flash mode and then when it's going to start erasing the flash area it stops with an error. And that is something that comes way back since previous versions. I am working now with 1.3.4, which I beleive it is the last one. I have no other idea of what should I try, since I attempted via USB flashing and UART and both fail in the same way. And I used the firmware from Octopus free section at boot-loader, since there is no other available on the net. If I had another packed in samsung's format and not octopus, perhaps I could have tried to flash them with another box and come back to Octopus for unlocking. One more detail is that all these C3313T I have tried to unlock come from Movilnet, Venezuela. And there are already several in town. Here is flashing log: Quote:
Now, what should I do next? Best regards, Zedd Last edited by zeddicus; 09-25-2013 at 02:07. | ||
