07-17-2013, 18:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 93292 Status: Offline Sonork: www.paypal.me/FGSM Thanks Meter: 83 | i have problem to flash samsung i9300 i cant flash samsung i9300 dead // screen white //, phone can b enter in downloading mode Welcome to Octoplus/Octopus Box Samsung software version 1.2.4 ----------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. Selected firmware file: GT-I9300_Root.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Please select firmware with PIT Writing Firmware Failed Operation was canceled |
The Following User Says Thank You to Mierdita For This Useful Post: |
07-18-2013, 06:05 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As You can see, there is damaged partitions info in phone's flash chip: Quote:
07-18-2013, 12:41 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If after of writing firmware with PIT the problem still remains - the problem is with phone's flash chip. Try to replace it. |
07-18-2013, 15:28 | #7 (permalink) |
Member: 93292 Status: Offline Sonork: www.paypal.me/FGSM Thanks Meter: 83 | Welcome to Octoplus/Octopus Box Samsung software version 1.2.4 ----------------------------------------------------------------------------- To connect GT-I9003 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Press "Read Info" in software. ----------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. Selected firmware file: PIT_I9300XXBLH1_I9300ITVBLH2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed |
