06-19-2015, 23:23 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Argentina
Member: 322470 Status: Offline Sonork: 1596253 Thanks Meter: 25 | i need efs for SM-N910s , Thanks To connect SM-N910S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: SM-N910S Selected file: H:\G\G\Soft cel\Cert-SM-N910S_354678060615684.cert Modelo del teléfono detectado: SM-N910S Fecha de creación del firmware: Sat Oct 4 23:19:58 KST 2014 PDA version: N910SKSU1ANJ1 CSC version: N910SSKC1ANJ1 Versión del SW: N910SKSU0ANJ1 IMEI del teléfono: 000000000000000 Phone SN: 00000000000 Android version: 4.4.4 (KTU84P) Checking Root: Phone is not Rooted. Writing Certificate failed ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: SM-N910S Selected file: H:\G\G\Soft cel\Cert-SM-N910S_354678060615684.cert ADB server killed. Modelo del teléfono detectado: SM-N910S Fecha de creación del firmware: Sat Oct 4 23:19:58 KST 2014 PDA version: N910SKSU1ANJ1 CSC version: N910SSKC1ANJ1 Versión del SW: N910SKSU0ANJ1 IMEI del teléfono: 000000000000000 Phone SN: 00000000000 Android version: 4.4.4 (KTU84P) Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed |
06-20-2015, 09:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. In order to connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. |
06-22-2015, 15:46 | #3 (permalink) |
Member: 322470 Status: Offline Sonork: 1596253 Thanks Meter: 25 | INFO : 22/06/2015 11:17:37 > Platform: Samsung Android INFO : 22/06/2015 11:17:37 > Selected port: COM4 INFO : 22/06/2015 11:17:38 > Selected model: SM-N910S INFO : 22/06/2015 11:17:45 > Selected file: C:\Users\Daniel\Downloads\Cert-SM-N910S_354678060615684.cert WARN : 22/06/2015 11:17:46 > Please, press "OK" button on the phone to allow USB debugging.. INFO : 22/06/2015 11:17:49 > Detected phone model: SM-N910S INFO : 22/06/2015 11:17:49 > Firmware compiled date: Sat Oct 4 23:19:58 KST 2014 INFO : 22/06/2015 11:17:49 > PDA version: N910SKSU1ANJ1 INFO : 22/06/2015 11:17:50 > CSC version: N910SSKC1ANJ1 INFO : 22/06/2015 11:17:50 > SW version: N910SKSU0ANJ1 INFO : 22/06/2015 11:17:52 > Phone IMEI: 000000000000000 INFO : 22/06/2015 11:17:52 > Phone SN: 00000000000 INFO : 22/06/2015 11:17:52 > Android version: 4.4.4 (KTU84P) INFO : 22/06/2015 11:17:52 > Checking Root: INFO : 22/06/2015 11:17:53 > Phone is Rooted. INFO : 22/06/2015 11:17:53 > Reading security backup, please wait... WARN : 22/06/2015 11:18:32 > Phone will restart now. Please don't disconnect cable! WARN : 22/06/2015 11:19:55 > Perform the following steps: WARN : 22/06/2015 11:19:55 > 1. Connect phone via UART cable to the Box. WARN : 22/06/2015 11:19:55 > 2. Note: phone screen must be active INFO : 22/06/2015 11:19:55 > Connecting to phone, please wait... INFO : 22/06/2015 11:20:00 > Found phone on COM4 INFO : 22/06/2015 11:20:00 > Phone connected successfully INFO : 22/06/2015 11:20:00 > Checking Certificate file... wait more than 40 minutes and does nothing, any ideas? thank |
06-22-2015, 16:26 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please download "Cert-SM-N910S_354678060615684.cert" Certificate file from the Support Area again and repeat "Write Cert" operation. |
01-09-2017, 05:14 | #6 (permalink) | |
Freak Poster Join Date: Nov 2012 Location: Uzbekistan Namangan
Member: 1845469 Status: Offline Thanks Meter: 17 | please help write cert failed Quote:
01-09-2017, 10:29 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please install the latest Software version and repeat "Write Cert" operation. If problem will remain the same - reflash the phone, then try to write a Cert file again. |
The Following 4 Users Say Thank You to Octopus box For This Useful Post: |
01-10-2017, 06:42 | #8 (permalink) | ||
Member: 1845469 Status: Offline Thanks Meter: 17 | Quote:
01-10-2017, 08:56 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please upload the following files to any file-sharing service: 1. Security backup of the phone. You can make a backup via "Read Security" operation. 2. *.log and *.logx files of performed operations. Files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. Post here download link for these 3 files and we will check what causes the problem. |
01-10-2017, 09:23 | #10 (permalink) | ||
Log file | ||
01-10-2017, 09:51 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please contact us to Skype, or Yahoo! Messenger, we'll check where can be the problem with the phone. Our contacts You can find in our profile. |
02-04-2017, 10:53 | #12 (permalink) |
Freak Poster Join Date: Feb 2007 Location: thailand
Member: 451521 Status: Offline Thanks Meter: 317 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-N910S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N910L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N910K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N910C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N910H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N910S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SM-N910S Selected file: C:\Users\TESTMODESHOP\Desktop\New folder\SM- N910S_354678060615676_0516.cert Detected phone model: SM-N910S Firmware compiled date: Thu Nov 24 17:07:09 KST 2016 PDA version: N910SKSU2DPK2 CSC version: N910SSKC2DPK2 SW version: N910SKSU0DPK2 Android version: 6.0.1 (MMB29K) Sales code: SKC Country: KOREA HW platform: exynos5 HW Chip: exynos5433 HW Modem: SS303 Security patch level: 2016-11-01 Codename: trelteskt Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found more then one box connected to COM40 Found phone on COM40 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- To connect SM-N920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N910C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect GT-P3100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. |
02-04-2017, 11:23 | #13 (permalink) |
03-16-2017, 10:25 | #14 (permalink) |
Freak Poster Join Date: May 2010 Location: angeles city,pampanga Age: 45
Member: 1304373 Status: Offline Thanks Meter: 31 | same problem of mine same model n910s.but icant find cert, file from octoplus support.my imei is 000000000000000.hoping that someone would give certificate file for the said model. |
03-16-2017, 11:03 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Cert files, which we have at the moment, are available in "Samsung/For unlock and repair/Certificates" folder of the Support Area (Cert files compatibility). To access Support Area, press "Go to support" button on "Support & options" tab of the Software. |
