10-29-2014, 22:32 | #1 (permalink) |
Crazy Poster Join Date: Jan 2014
Member: 2101196 Status: Offline Thanks Meter: 6 | i need help sm-g900a [Solved] Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SGH-I497 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G900A Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM45 Mode: Normal Phone model: SM-G900A Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Apr 15 2014 Firmware released time: 14:21:37 Phone IMEI: 353502-06-035474-1 SW version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A To Unlock of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A Detected phone model: SM-G900A Firmware compiled date: Wed Apr 16 15:18:57 KST 2014 PDA version: G900AUCU2AND3 CSC version: G900AATT2AND3 SW version: G900AUCU2AND3 Phone IMEI: 353502060354741 Phone SN: R38F30ZRPME Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Apr 15 2014 Firmware released time: 14:21:37 SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\QCN-SM-G900A-353502060354741-29-10-2014_17-13-48-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G900A-353502060354741-29-10-2014_17-17-31-.asec file Wiping EFS... EFS wipe successfully Phone will restart now Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Feb 26 2014 Firmware compiled time: 01:00:00 Firmware released date: Apr 15 2014 Firmware released time: 14:21:37 SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A Selected file: C:\Users\m\Desktop\cert for s5\SM-G900H_353285066458472_RF1F4.cert Detected phone model: SM-G900A Firmware compiled date: Wed Apr 16 15:18:57 KST 2014 PDA version: G900AUCU2AND3 CSC version: G900AATT2AND3 SW version: G900AUCU2AND3 Phone IMEI: Unknown Phone SN: R38F30ZRPME Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A Selected file: C:\Users\m\Desktop\cert for s5\SM-G900H_353415064151122_R51F600P1C.cert Detected phone model: SM-G900A Firmware compiled date: Wed Apr 16 15:18:57 KST 2014 PDA version: G900AUCU2AND3 CSC version: G900AATT2AND3 SW version: G900AUCU2AND3 Phone IMEI: Unknown Phone SN: R38F30ZRPME Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A Selected file: C:\Users\m\Desktop\cert for s5\SM-G900H_353285066458472_RF1F4.cert Detected phone model: SM-G900A Firmware compiled date: Wed Apr 16 15:18:57 KST 2014 PDA version: G900AUCU2AND3 CSC version: G900AATT2AND3 SW version: G900AUCU2AND3 Phone IMEI: Unknown Phone SN: R38F30ZRPME Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A Selected file: C:\Users\m\Desktop\cert for s5\SM-G900H_353285066458472_RF1F4-1.cert Detected phone model: SM-G900A Firmware compiled date: Wed Apr 16 15:18:57 KST 2014 PDA version: G900AUCU2AND3 CSC version: G900AATT2AND3 SW version: G900AUCU2AND3 Phone IMEI: Unknown Phone SN: R38F30ZRPME Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM45 Selected model: SM-G900A Selected file: C:\Users\m\Desktop\cert for s5\SM-G900H_353415064151122_R51F600P1C.cert Detected phone model: SM-G900A Firmware compiled date: Wed Apr 16 15:18:57 KST 2014 PDA version: G900AUCU2AND3 CSC version: G900AATT2AND3 SW version: G900AUCU2AND3 Phone IMEI: Unknown Phone SN: R38F30ZRPME Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed Last edited by Octopus box; 10-30-2014 at 11:53. |
10-30-2014, 07:34 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. You have done all operations correctly, but You have used unsuitable Certificate: Quote:
