01-22-2014, 00:46 | #1 (permalink) |
Junior Member Join Date: Oct 2008
Member: 880355 Status: Offline Thanks Meter: 0 | i317m no agarra telcel despues de liberar Alguien sabe como corregir ese fallo ? Plataforma: Samsung Android Puerto seleccionado: COM101 Modelo seleccionado: SGH-I317M Modo: Normal Modelo del teléfono: ACEFWMAZ Warning: Selected model (SGH-I317M) differs from the detected one (ACEFWMAZ)! Fecha de creación del firmware: Nov 11 2012 Tiempo de compilación del firmware: 08:00:00 Fecha de salida del firmware: Feb 20 2013 Tiempo de salida del firmware: 12:39:24 Versión del SW: M9615ACEHWMAZD17515030 IMEI antiguo: 356216-05-048069-0 IMEI nuevo: 356236-05-048069-8 IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
01-22-2014, 01:11 | #2 (permalink) |
Member: 880355 Status: Offline Thanks Meter: 0 | sorry maybe in english you can help me, I unlock the samsung i317m Telcel with octopus box using samsung software, it worked i can use movistar, iusacell but the original company telcel doesn't work it shows emergency calls only or sometimes it says Unregistered Sim, I tried to fix the nvm, change imei and everything said successfully but it doesn't change the imei, it says successfully but doesn't change it. Can anybody help me, how can i fix this? i don't care if i can't use other chips but i need it to work whit the original company Telcel. Thanks in advanced. |
01-22-2014, 18:21 | #4 (permalink) |
Member: 880355 Status: Offline Thanks Meter: 0 | I flash a canadian rom, then unlock and it worked but i can't use the original chip, so I re-flash wit an original rom telcel but still doesn't work, I am going to look another rom from telcel to see what happens |
04-01-2014, 01:53 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: *** USA ***
Member: 97760 Status: Offline Thanks Meter: 64 | I have same problem, i317 is Telcel Mexico, i run firmw, root , unlock, but same error unregister sim, or emergency call, i run firmw telcel, claro, rogers 4.1.1 telcel 4.3 i flashing, but only work in unefon mexico, what is problem? |
04-03-2014, 19:26 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | There two firmwares for SGH-I337 on the Support Area. Try to write both of them. Last edited by Octopus box; 04-04-2014 at 07:00. |
