02-27-2016, 08:50 | #1 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 532257 Status: Offline Sonork: 1624266 Thanks Meter: 64 | i337m s4 octopus help me log here and tell me Welcome to Octoplus/Octopus Box Samsung software version 2.2.0 ----------------------------------------------------------------------------------- To connect SGH-I337M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM19 Selected model: SGH-I337M Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Mode: Normal Phone model: SGH-I337M Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Reading EFS failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SGH-I337M Firmware compiled date: Thu May 1 23:13:25 KST 2014 PDA version: I337MVLUFNE1 CSC version: I337MOYAFNE2 SW version: I337MVLUFNE1 Phone IMEI: 355794051202785 Phone SN: R31D41MH1AT Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Security read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SGH-I337M Firmware compiled date: Thu May 1 23:13:25 KST 2014 PDA version: I337MVLUFNE1 CSC version: I337MOYAFNE2 SW version: I337MVLUFNE1 Phone IMEI: 355794051202785 Phone SN: R31D41MH1AT Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading EFS, please wait... EFS read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SGH-I337M Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SGH-I337M Firmware compiled date: Thu May 1 23:13:25 KST 2014 PDA version: I337MVLUFNE1 CSC version: I337MOYAFNE2 SW version: I337MVLUFNE1 Phone IMEI: 355794051202785 Phone SN: R31D41MH1AT Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-I337M Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SGH-I337M Firmware compiled date: Thu May 1 23:13:25 KST 2014 PDA version: I337MVLUFNE1 CSC version: I337MOYAFNE2 SW version: I337MVLUFNE1 Phone IMEI: 355794051202785 Phone SN: R31D41MH1AT Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed |
02-27-2016, 08:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try write QCN, You should connect the phone in Qualcomm mode. To connect SGH-I337M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. When phone's info will be read out successfully in Qualcomm mode, You can perform Read/Write QCN operation. Also, try to select correct COM port manually. Last edited by Octopus box; 02-27-2016 at 13:51. |
02-27-2016, 09:07 | #3 (permalink) |
Member: 532257 Status: Offline Sonork: 1624266 Thanks Meter: 64 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.0 ----------------------------------------------------------------------------------- To connect SGH-I337M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SGH-I337M Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SGH-I337M Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Reading info, please wait... Detected phone model: SGH-I337M Firmware compiled date: Thu May 1 23:13:25 KST 2014 PDA version: I337MVLUFNE1 CSC version: I337MOYAFNE2 SW version: I337MVLUFNE1 Phone IMEI: 355794051202785 Phone SN: R31D41MH1AT Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed same problem |
02-27-2016, 09:14 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To connect the phone, try to perform the next steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" at the "Main" tab in the Software. |
02-27-2016, 10:02 | #5 (permalink) |
Member: 532257 Status: Offline Sonork: 1624266 Thanks Meter: 64 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Reading info, please wait... Detected phone model: SGH-I337M Firmware compiled date: Thu May 1 23:13:25 KST 2014 PDA version: I337MVLUFNE1 CSC version: I337MOYAFNE2 SW version: I337MVLUFNE1 Phone IMEI: 355794051202785 Phone SN: R31D41MH1AT Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-I337M Reading info... Phone was not found on the selected port! Reading QCN failed same problem |
