05-30-2014, 12:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | I437 Not Unlock ----------------------------------------------------------------------------------- To connect SGH-I437 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM426 Selected model: SGH-I437 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM425 Mode: Normal Phone model: AAAAANAZ Phone model is not supported Phone connection failed Connecting to phone on COM426 Mode: Emergency ----------------------------------------------------------------------------------- To connect SGH-I437 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM426 Selected model: SGH-I437 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM425 Port is busy Connecting to phone on COM426 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM425 Selected model: SGH-I437 Mode: Normal Phone model: AAAAANAZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM425 Mode: Normal Phone model: AAAAANAZ Phone model is not supported Phone connection failed Connecting to phone on COM426 Mode: Emergency |
05-30-2014, 12:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Your device was detected by Software as "AAAAANAZ", not as "SGH-I437". Do the next: select COM port manually, select device model, check (select) "Manual select" options in Software and try again. |
05-30-2014, 12:47 | #3 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | When i tik option Manual select show this only. Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect SGH-I437 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM426 Selected model: SGH-I437 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM425 Selected model: SGH-I437 Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM359 Selected model: SGH-I437 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM426 Selected model: SGH-I437 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM425 Mode: Normal Phone model: AAAAANAZ Phone model is not supported Phone connection failed Connecting to phone on COM426 Mode: Emergency ----------------------------------------------------------------------------------- To connect SGH-I437 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM426 Selected model: SGH-I437 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM425 Phone connection failed Connecting to phone on COM426 Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM426 Selected model: SGH-I437 Phone was not found on the selected port! |
05-30-2014, 13:03 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Contact us right now to Skype, Sonork, Yahoo! Messenger or ICQ, we will look remotely via Team Viewer. Our contacts You can find in our profile. |
