01-14-2014, 16:28 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: tirana
Member: 1254195 Status: Offline Sonork: 5454 Thanks Meter: 119 | I437P Unlock solution or not? [Solved] I search many time for correct answer for thiss phone but nothing,can Octopus Box unlock thiss phone if yes share solution.Thanks Last edited by Octopus box; 01-16-2014 at 09:30. |
01-14-2014, 16:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Octopus/Octoplus Box Samsung Software currently supports "Unlock" SGH-I437 (SGH-I437P was not tested, so we haven't added it to the list of supported devices). You can try connect your SGH-I437P as SGH-I437 (select SGH-I437 in list and select "Manul select" option in Software) and try to perform "Unlock" or "Read codes" operation. To connect SGH-I437P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. If the combination "*#9090#" doesn't work, try to type "*#8080#" to access Qualcomm Settings. |
01-15-2014, 11:24 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Currently we haven't SGH-I437P in our hands, we haven't tested it and can't say to You exactly, whether there will not be any problems with the device after You write firmware for SGH-I437. You can do this for your own risk. |
01-15-2014, 11:42 | #5 (permalink) |
Member: 1254195 Status: Offline Sonork: 5454 Thanks Meter: 119 | For that i ask you bro,i know model which are supported with Octopus Box are very safe to flash,but i see i437P its not in list,i leave it bro.Thanks for quick answer. |
01-15-2014, 23:41 | #6 (permalink) |
Member: 1254195 Status: Offline Sonork: 5454 Thanks Meter: 119 | Sucessfull Unlocked I437P,Thanks for support Octopus Box but need direct unlock bcz i do many trick to unlock thiss phone,very hard right now to unlock but Done. B.R |
01-16-2014, 08:27 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Thanks for your report. Can You describe your solution step by step for all users? Also, please post here full Software log with all of your actions. |
01-16-2014, 09:22 | #8 (permalink) |
Member: 1254195 Status: Offline Sonork: 5454 Thanks Meter: 119 | 1.Flash with Octopus Box firmware of I437,sure i have lose Wi-Fi and thiss need to focuse everytime to fix wi-fi problem,dont forget to Wipe Factory Reset in Recovery mode after flash with Octopus Box. 2.Update bootloader with thiss software Express-OUDHS-CWM 3.Unlock with Box 4.If you want to solve Wi-Fi problem,lets install thiss rom cm-10.2-20130831-UNOFFICIAL-expressatt.zip from SD Card,sure after root with UPDATE-SuperSU-v1.25.zip 5.Install gapps-jb-20130813-signed.zip from SD Card for some required apps in android phones. I437P Unlocked working well now 4.3 version and full signal. Last edited by Octopus box; 01-16-2014 at 09:30. |
