05-31-2014, 07:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Repair of what? IMEI? Repair IMEI for SGH-I537 with 4.4.2 Android versions firmwares was not tested. Try to root the device and perform Repair IMEI operation. Then post here full Software log. |
06-01-2014, 01:13 | #3 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2101398 Status: Offline Thanks Meter: 8 | Octoplus team I537 on 4.4.2 I downgraded to 4.3 and rooted successfully. Dialed *#9090# and chose first option as per instructions, the phone rebooted and baseband UKNOWN and IMEI NULL. I have been going in circles for hours. I flashed the MFI and ML2 modem by Odin and failed. I can't find other modems. I think Im on NC9 bootloader. Any solution? |
06-01-2014, 03:13 | #4 (permalink) |
Member: 2101398 Status: Offline Thanks Meter: 8 | I Flashed I537UBUBML3_I537TCEBML3_TCE_Mexico(Telcel)_Android _4.3.OCT firmawire But Baseband still unknown. --------- To put SGH-I537 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Firmware writing successfully completed. |
06-01-2014, 08:45 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
Try to re-flash the device with different firmwares which You have and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct), perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
06-01-2014, 16:45 | #6 (permalink) |
Member: 2101398 Status: Offline Thanks Meter: 8 | I got the baseband MF1 flashed by odin. I think I was flashing corrupt MF1 before . I did repair and went flawlessly. Remember not to select option one on *#9090# Here is the log ------------------------------ INFO : 6/1/2014 12:24:24 AM > Platform: Samsung Android INFO : 6/1/2014 12:24:24 AM > Selected port: COM8 INFO : 6/1/2014 12:24:24 AM > Selected model: SGH-I537 INFO : 6/1/2014 12:24:25 AM > Phone was not found on the selected port! INFO : 6/1/2014 12:24:26 AM > Searching for USB diagnostic port... INFO : 6/1/2014 12:24:26 AM > Connecting to phone on COM6 INFO : 6/1/2014 12:24:26 AM > Mode: Normal INFO : 6/1/2014 12:24:26 AM > Phone model: SGH-I537 INFO : 6/1/2014 12:24:26 AM > Firmware compiled date: May 08 2013 INFO : 6/1/2014 12:24:26 AM > Firmware compiled time: 20:00:00 INFO : 6/1/2014 12:24:26 AM > Firmware released date: May 31 2013 INFO : 6/1/2014 12:24:26 AM > Firmware released time: 21:03:48 INFO : 6/1/2014 12:24:26 AM > Phone IMEI: ******* INFO : 6/1/2014 12:24:26 AM > SW version: M9615A-CEFWTAZM-4.0.17081 INFO : 6/1/2014 12:24:38 AM > ----------------------------------------------------------------------------------- INFO : 6/1/2014 12:24:38 AM > Platform: Samsung Android INFO : 6/1/2014 12:24:38 AM > Selected port: COM6 INFO : 6/1/2014 12:24:38 AM > Selected model: SGH-I537 INFO : 6/1/2014 12:24:38 AM > Mode: Normal INFO : 6/1/2014 12:24:38 AM > Phone model: SGH-I537 INFO : 6/1/2014 12:24:38 AM > Firmware compiled date: May 08 2013 INFO : 6/1/2014 12:24:38 AM > Firmware compiled time: 20:00:00 INFO : 6/1/2014 12:24:38 AM > Firmware released date: May 31 2013 INFO : 6/1/2014 12:24:38 AM > Firmware released time: 21:03:48 INFO : 6/1/2014 12:24:38 AM > SW version: M9615A-CEFWTAZM-4.0.17081 INFO : 6/1/2014 12:24:38 AM > Old IMEI: ****** INFO : 6/1/2014 12:24:38 AM > New IMEI: ****** INFO : 6/1/2014 12:24:38 AM > Creating NVM backup INFO : 6/1/2014 12:26:52 AM > Reading NVM done! INFO : 6/1/2014 12:26:52 AM > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-I537-*****-01-06-2014_00-24-38-.nvm file INFO : 6/1/2014 12:26:53 AM > ADB server killed. INFO : 6/1/2014 12:26:55 AM > Firmware compiled date: Tue Mar 25 23:26:30 KST 2014 INFO : 6/1/2014 12:26:55 AM > PDA version: I537UCUCNC9 INFO : 6/1/2014 12:26:56 AM > CSC version: I537ATTCNC9 INFO : 6/1/2014 12:26:56 AM > SW version: I537UCUAMF1 INFO : 6/1/2014 12:26:57 AM > Phone IMEI: ******* INFO : 6/1/2014 12:26:58 AM > Phone SN: ****** INFO : 6/1/2014 12:26:58 AM > Android version: 4.4.2 (KOT49H) INFO : 6/1/2014 12:26:58 AM > Cheking Root INFO : 6/1/2014 12:27:00 AM > Phone is Rooted INFO : 6/1/2014 12:27:00 AM > Erasing old IMEI. It can take some time. Please wait... WARN : 6/1/2014 12:27:15 AM > Phone will restart now. Please don't disconnect cable! INFO : 6/1/2014 12:27:57 AM > Firmware compiled date: May 08 2013 INFO : 6/1/2014 12:27:57 AM > Firmware compiled time: 20:00:00 INFO : 6/1/2014 12:27:57 AM > Firmware released date: May 31 2013 INFO : 6/1/2014 12:27:57 AM > Firmware released time: 21:03:48 INFO : 6/1/2014 12:27:57 AM > SW version: M9615A-CEFWTAZM-4.0.17081 INFO : 6/1/2014 12:27:57 AM > Found phone on COM6 INFO : 6/1/2014 12:27:58 AM > Repairing NVM for SGH-I537 phone... INFO : 6/1/2014 12:28:09 AM > IMEI successfully repaired. WARN : 6/1/2014 12:28:09 AM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
The Following User Says Thank You to mrgj For This Useful Post: |
