03-30-2014, 19:31 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2147907 Status: Offline Thanks Meter: 1 | I537 after imei repair...network keep disconnecting !!! First i tried to direct unlock the device...every thing is ok till the process reach ( disable msl )...then the device will restart and octopus tool will ask to keep the device connected... after the device rebooted an error will show up ( nvm repair failed ). After this process the device lost the imei...so i did imei repair for the device and it was ok...now the connection to the network keep disconnect !!! Would you mind to give me a solution !!! Sent from my GT-I9505G using Tapatalk |
03-31-2014, 06:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to do the next: 1. Install the latest Software version (Software). 2. Perform the Repair NVM operation. 3. Re-boot the device. 4. Insert SIM card, wait 3-5 minutes and try to find and select network manually. 5. Write here the result. |
03-31-2014, 09:15 | #3 (permalink) | |
Member: 2147907 Status: Offline Thanks Meter: 1 | Quote:
04-08-2014, 06:59 | #4 (permalink) |
Member: 2147907 Status: Offline Thanks Meter: 1 | hi octopus, i successfully repaired NVM....the phone was ok for two days...then the call start to be unclear, after that it started to drop network connections but less frequently. any suggestion please ? |
05-02-2014, 04:09 | #6 (permalink) | |
I am facing a strange issue with this phone...I did as you said and nothing changed !!! but I noticed something strange...in my country there are two carriers...one of them is operate on 900 MHz(Jawwal Palestine) and the other on 1800 MHz(PS, Wataniya)...the disconnecting only happening on 900 MHz(Jawwal Palaestine) while the other is steady and stable !!! oh one more thing .... I tried to set the operation frequency to only GSM 900/1800 by dialing *#2263# but the issue persist !!! any help ??? Last edited by AL-Rayyan@GSM; 05-02-2014 at 04:23. | |
05-02-2014, 13:17 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | if You have tried to re-flash the phone and made repair NVM and the problem is the same, currently we have no other solution. Also, accordingly to your notes: Quote:
05-02-2014, 13:25 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Yes, You can try to update firmware. Please fully charge phone's battery before and make backups of phone's Security and EFS. |
05-02-2014, 16:14 | #12 (permalink) |
Member: 2147907 Status: Offline Thanks Meter: 1 | Welcome to Octoplus/Octopus Box Samsung software version 1.5.2 ----------------------------------------------------------------------------------- To connect SGH-I537 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM63 Selected model: SGH-I537 Mode: Emergency NVM can’t be repaired for SGH-I537 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM63 Selected model: SGH-I537 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM61 Selected model: SGH-I537 Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM62 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Repairing NVM for SGH-I537 phone... Writing NVM failed NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
