05-14-2016, 11:39 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to make Factory Reset. Try to reflash the phone. If problem will remain - You can try to process the phone via UART. |
05-25-2016, 06:13 | #3 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Vancouver
Member: 190184 Status: Offline Thanks Meter: 31 | If I reflash the phone with lower version I get huge yellow triangle that says that I should go to Verizon because i have unautorised software and then i have to reflash to its current version to back the phone to life. I am doing this because on lower versions the codes should work but they removed that feature in later ones. |
05-25-2016, 11:01 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately it is not always possible to downgrade phone firmware version. Try to reflash the phone with "i535vrudne1_i535vzwdne1_vzw_android_4.4.2" firmware from the Support Area. |
05-27-2016, 11:09 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to enter *#22745927 code. If menu will open - select Hidden Menu, select Enabled and press OK. Check whether other codes work after these actions. |
05-28-2016, 09:15 | #7 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Follow these steps, I have a Verizon I535 with Kitkat 4.4.2. 1. Download TowelRoot. 2. Enable Install from Unknown Sources 3. Install TowelRoot, install regardless of the warnings. 4. Install SuperSU from the Google store You now have root access. 5. Install ES File Explorer from Google Play. 6. In ES File Explorer goto Settings->Tools 7. Turn on Root Explorer 8. Turn on Show Hidden Files 9. Use ES File Explorer to find /efs/Carrier/HiddenMenu 10. Open this file as text using ES Note Editor. 11. In the upper right corner of ES Note Editor select the menu icon then select EDIT 12. Change the text OFF to ON 13. Exit and save the file. 14. Reboot and then try the codes. The service test screen is *#0*#. |
05-28-2016, 09:26 | #8 (permalink) |
Member: 190184 Status: Offline Thanks Meter: 31 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.6 ----------------------------------------------------------------------------------- To connect SGH-I747 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SCH-I535 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#22745927" number. 7. In Hidden Menu select "enable" radio button. 8. Go to dial window. 9. Enter "*#7284#" number. 10. Set "UART" radio button to "PDA" value. 11. Go to "Qualcomm USB Settings". 12. Select "RNDIS+DM+MODEM". 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SCH-I535 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM41 Mode: Normal Phone model: SCH-I535 Firmware compiled date: Apr 21 2014 Firmware compiled time: I535.10 Firmware released date: May 20 2014 Firmware released time: 00:51:16 Phone IMEI: 990003-48-980469-6 SW version: M8960A-AAAANAZM-1.0.443136 Performed by 2.2.6 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SCH-I535 Mode: Normal Phone model: SCH-I535 Firmware compiled date: Apr 21 2014 Firmware compiled time: I535.10 Firmware released date: May 20 2014 Firmware released time: 00:51:16 SW version: M8960A-AAAANAZM-1.0.443136 Old IMEI: 990003-48-980469-6 New IMEI: 369552-14-987763-6 Repairing IMEI. Please wait... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.2.6 software version This operation does nothing as the IMEI stays the same old one |
05-28-2016, 12:47 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
