11-06-2014, 15:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Ghana
Member: 1230787 Status: Offline Thanks Meter: 96 | i727 imei repair problem Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM28 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM28 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I727 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM28 Mode: Emergency |
11-06-2014, 16:09 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Mode:Emergency means that phone was not configured correctly for connection. 1.Disconnect Micro USB cable from phone 2. Go to Menu->Settings->Applications->Development 3. Turn on "USB Debugging" option 4. When message is appear press "Yes" 5. Go to dial window 6. Enter "*#7284#" number 7. Set "USB" radio button to "Modem" value 8. Set "UART" radio button to "Modem" value 9. Close window 10. Go to dial window 11. Enter "*#9090#" number 12. Set "Diag config" to "USB" value 13. Restart phone 14. Connect the phone directly to PC. 15. Press "Read Info" in Octopus Samsung software Install latest Software version (Software). Also try to re-flash the phone and connect it again. Last edited by Octopus box; 11-06-2014 at 16:15. |
11-06-2014, 17:06 | #3 (permalink) |
Member: 1230787 Status: Offline Thanks Meter: 96 | now whn i connect it show different model.... Welcome to Octoplus/Octopus Box Samsung software version 1.7.4 ----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM28 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I727 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM28 Mode: Emergency |
11-06-2014, 17:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to select another COM port manually, select (check) "Manual select" option and repeat the operation once again. |
11-07-2014, 12:26 | #5 (permalink) |
Member: 1230787 Status: Offline Thanks Meter: 96 | i cant seem to connect any phone again....ive tried with three different samsung phones but gives me the same error message.... Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM3 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM3 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM3 Phone connection failed |
