10-31-2014, 10:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | I747m how to read code? [Solved] please help for unlock this phone!!!! Code: Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SGH-I747M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747M Mode: Emergency Codes for SGH-I747M phone in emergency mode can’t be read ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-I747M Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM72 Mode: Emergency Last edited by Octopus box; 02-26-2015 at 14:37. |
10-31-2014, 10:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You have not connected the device correctly. To connect SGH-I747M, perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. |
02-26-2015, 09:53 | #4 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | Platform: Samsung Android INFO : 26/02/2015 1:51:34 PM > Selected port: COM273 INFO : 26/02/2015 1:51:35 PM > Selected model: SGH-I747M INFO : 26/02/2015 1:51:35 PM > Mode: Normal INFO : 26/02/2015 1:51:35 PM > Phone model: SGH-I747M INFO : 26/02/2015 1:51:35 PM > Firmware compiled date: Nov 13 2013 INFO : 26/02/2015 1:51:35 PM > Firmware compiled time: 00:00:00 INFO : 26/02/2015 1:51:35 PM > Firmware released date: Nov 19 2013 INFO : 26/02/2015 1:51:35 PM > Firmware released time: 20:17:24 INFO : 26/02/2015 1:51:35 PM > Phone IMEI: 353323-05-303402-0 INFO : 26/02/2015 1:51:35 PM > SW version: M8960A-AAAANAZM-1.0.443100 INFO : 26/02/2015 1:51:35 PM > Reading phone unlock codes. It can take some time, please wait... ERROR : 26/02/2015 1:51:35 PM > Reading security failed ERROR : 26/02/2015 1:51:35 PM > Read codes failed how to read codes or unlock? Last edited by aikonmani; 02-26-2015 at 09:55. Reason: edit |
02-26-2015, 09:59 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You devcie has new security type, currently it is impossible to read codes in this device. Try to make Direct Unlock. Don't forget to read out Security, EFS and QCN backups. |
02-26-2015, 11:09 | #6 (permalink) | |
Member: 304090 Status: Offline Thanks Meter: 210 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.8.5 ----------------------------------------------------------------------------------- To connect SGH-I747 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I747M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM273 Selected model: SGH-I747M Reading info, please wait... Detected phone model: SGH-I747M Firmware compiled date: Tue Nov 19 19:41:38 KST 2013 PDA version: I747MVLUEMK5 CSC version: I747MOYBEMK5 SW version: I747MVLUEMK5 Phone IMEI: 353323053034020 Phone SN: R21CB3NJZQY Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM273 Selected model: SGH-I747M Detected phone model: SGH-I747M Firmware compiled date: Tue Nov 19 19:41:38 KST 2013 PDA version: I747MVLUEMK5 CSC version: I747MOYBEMK5 SW version: I747MVLUEMK5 Phone IMEI: 353323053034020 Phone SN: R21CB3NJZQY Android version: 4.3 (JSS15J) Reading security backup, please wait... Security read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM273 Selected model: SGH-I747M Detected phone model: SGH-I747M Firmware compiled date: Tue Nov 19 19:41:38 KST 2013 PDA version: I747MVLUEMK5 CSC version: I747MOYBEMK5 SW version: I747MVLUEMK5 Phone IMEI: 353323053034020 Phone SN: R21CB3NJZQY Android version: 4.3 (JSS15J) Reading EFS, please wait... EFS read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM273 Selected model: SGH-I747M Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM273 Selected model: SGH-I747M Reading QCN failed | |
02-26-2015, 11:14 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To read QCN, You should connect (configure) the phone correctly. To connect SGH-I747, perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" at the "Main" tab in the Software. When phone's info will be read out from the "Main" tab in the Software, make Read QCN. |
02-26-2015, 12:10 | #10 (permalink) |
Member: 304090 Status: Offline Thanks Meter: 210 | Welcome to Octoplus/Octopus Box Samsung software version 1.8.5 ----------------------------------------------------------------------------------- To connect SGH-I747M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM273 Selected model: SGH-I747M Reading info, please wait... Detected phone model: SGH-I747M Firmware compiled date: Tue Nov 19 19:41:38 KST 2013 PDA version: I747MVLUEMK5 CSC version: I747MOYBEMK5 SW version: I747MVLUEMK5 Phone IMEI: 353323053034020 Phone SN: R21CB3NJZQY Android version: 4.3 (JSS15J) |
02-26-2015, 12:26 | #12 (permalink) |
Member: 304090 Status: Offline Thanks Meter: 210 | this is read from main tab..... Welcome to Octoplus/Octopus Box Samsung software version 1.8.5 ----------------------------------------------------------------------------------- To connect SGH-I747 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I747M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM273 Selected model: SGH-I747M Mode: Normal Phone model: SGH-I747 Firmware compiled date: Nov 13 2013 Firmware compiled time: 00:00:00 Firmware released date: Nov 19 2013 Firmware released time: 20:17:24 Phone IMEI: 353323-05-303402-0 SW version: M8960A-AAAANAZM-1.0.443100 |
02-26-2015, 12:51 | #14 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | After info is read our correctly, like here: Quote:
