08-30-2014, 23:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Inside you
Member: 204827 Status: Offline Thanks Meter: 46 | i747M imei null |
08-31-2014, 12:38 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ celutek Hello. Quote:
09-01-2014, 23:29 | #4 (permalink) | |
Member: 204827 Status: Offline Thanks Meter: 46 | Quote:
Plataforma: Samsung Android Puerto seleccionado: COM40 Modelo seleccionado: SGH-I747M Reading info, please wait... Modelo del teléfono detectado: SGH-I747M Fecha de creación del firmware: Mon Jun 3 20:10:12 KST 2013 PDA version: I747MVLDMF1 CSC version: I747MOYBDMF1 Versión del SW: Unknown IMEI del teléfono: Unknown Phone SN: R21CC4VHZNZ Android version: 4.1.2 (JZO54K) | |
09-02-2014, 06:27 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from your Software log, phone's modem part is damaged: Quote:
It is not possible to repair IMEI, if phone's modem part is damaged. Please re-flash the phone with different firmwares and after writing each firmware check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. | |
07-26-2015, 01:21 | #9 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 389266 Status: Offline Thanks Meter: 17 | Quote:
hello friend I have the same problem I have flashed several times with 4.3 4.1.1 and IMEI null my log Selected model: SGH-I747M Normal Mode Phone model: SGH-I747M Creation date of the firmware: Firmware compilation time: Departure Firmware: -u ~ Firmware out time: SW version: Old IMEI: Unknown New IMEI: 358309-05-533922-3 Performing the backup of NVM Reading NVM is finished! Creation date of the firmware: Sat November 24 2012 10:59:36 KST PDA version: I747MUMBLK3 CSC version: I747MTCEBLK4 SW Version: Unknown IMEI Phone: Unknown Phone SN: R21CA468WTP Android version: 4.1.1 (JRO03L) my question is: If Is the problem ic hw have to change ¿emmc? reball ic etc very thanks friend luck | |
07-27-2015, 09:02 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to re-flash the phone with different firmwares and after writing each firmware check, whether modem is correct (not Unknown). If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). |
