06-03-2015, 04:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205304 Status: Offline Thanks Meter: 52 | i8160 E:Can't mount [Solved] What is the solution E:Can't mount/cache E:Can't mount/recovery E:Can't mount/efs ? Phone can only enter recovery and download mode. access to full menu is impossible. how to fix ? - already flashed with different firmwares (.oct) still the same. Last edited by Octopus box; 06-11-2015 at 08:57. |
06-03-2015, 07:53 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Make Factory Reset and Wipe cache partition from recovery mode, then try to re-flash the phone with different firmwares again. If after writing of different firmwares problem will remain the same, then, most likely, your phone has WH problem (with phone's flash chip). |
