12-16-2014, 17:51 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | I8160 Writing firmware FAILED today i receiver samsung i8160 justo logo samsung after flash it with 2 diferent files and only failed Welcome to Octoplus/Octopus Box Samsung software version 1.7.7 ----------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. Selected firmware file: I8160XXNA1_I8160ITVNA1_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I8160 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Kernel section... Kernel section has been written successfully. Writing Modem section... Modem section has been written successfully. Writing Firmware Failed Selected firmware file: I8160NELE1_I8160HUILD2 _Italy_H3G_Android_2.3.6.oct Please put the phone into Download Mode and connect USB cable. To put GT-I8160 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing CACHEFS section... CACHEFS section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing Kernel section... Kernel section has been written successfully. Writing Modem section... Modem section has been written successfully. Writing SYSTEM section... Writing Firmware Failed |
12-17-2014, 08:04 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What is the problem with your phone exactly? Why You try to write firmware? Fully charge phone's battery, make Factory data reset and try to write firmware again. Also, this can be HW issue. |
