11-23-2014, 18:47 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | i8190 IMEI Null Show Repair Done But Also Null Code: Welcome to Octoplus/Octopus Box Samsung software version 1.7.6 ----------------------------------------------------------------------------------- To connect GT-I8190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Nov 16 20:00:33 KST 2012 PDA version: I8190XXALK6 CSC version: I8190OXAALK6 SW version: Unknown Phone IMEI: Unknown Phone SN: 00000000000 Android version: 4.1.1 (JRO03H) Old IMEI: Unknown New IMEI: 356768-68-787878-7 Cheking Root Phone is Rooted Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Writing new IMEI. Please wait... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Br Palash Ahammad |
11-23-2014, 18:49 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. Last edited by Octopus box; 11-23-2014 at 19:35. | |
11-23-2014, 19:17 | #3 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Can You Provide Me 3 File Package Firmware Like:- PDA: I8190XXALJL CSC: I8190CNXALJ4 PHONE: I8190CNXALJ4 I Already Download More Firmware But There Are 2 File Only PDA+CSC If You Can Possible Just Give Me Full Package Firmware. Thanks in Advance Br Palash Ahammad |
11-23-2014, 19:21 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Currently we don't have such firmware. We will try to find it and will upload into the Support Area, in case of success. |
11-23-2014, 19:37 | #7 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Phone Hardware is OK Its Destroy By Another Technician Use Thad Party Tools, So Its Software Problem Not in H/W Br Palash Ahammad |
11-24-2014, 07:42 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Write different firmwares from the Support Area one by one and check, whether modem is correct (whether SW version is not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. |
11-24-2014, 08:47 | #11 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1775732 Status: Offline Thanks Meter: 14 | http://dl.**************/PVBYSlkrLCk...BLAMF3_UBL.zip Model: GT-I8190 Model name: GALAXY S III mini Country: Uzbekistan Version: Android 4.1.2 Changelist: 1231497 Build date: Mon, 27 May 2013 03:05:05 +0000 Product Code: UBL PDA: I8190XXAME1 CSC: I8190UBLAMF3 MODEM: I8190XXAME1 full flash for you |
