06-07-2014, 14:25 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Spain
Member: 595735 Status: Offline Thanks Meter: 20 | i8190n uart not connected ----------------------------------------------------------------------------------- To connect GT-I8190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM480 Phone connection failed No diagnostic ports found! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Sat Dec 22 13:45:13 KST 2012 PDA version: I8190NXXALL6 CSC version: I8190NOXAALL6 SW version: I8190NXXALL6 Phone IMEI: Unknown Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Can't root Android version 2.3.3 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't root Android version 4.1.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM480 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed No diagnostic ports found! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM480 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed No diagnostic ports found! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Sat Dec 22 13:45:13 KST 2012 PDA version: I8190NXXALL6 CSC version: I8190NOXAALL6 SW version: I8190NXXALL6 Phone IMEI: 354785058686278 Phone SN: R21D3B1NDNP Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Phone is Rooted Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... any help???? |
06-07-2014, 16:35 | #4 (permalink) |
Member: 595735 Status: Offline Thanks Meter: 20 | same problem Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect GT-I8190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... ADB server killed. Phone found. Firmware compiled date: Thu Jul 4 13:59:27 KST 2013 PDA version: I8190NXXAMG1 CSC version: I8190NOXAAMG1 SW version: I8190NXXAMG1 Phone IMEI: 354785058686278 Phone SN: R21D3B1NDNP Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Thu Jul 4 13:59:27 KST 2013 PDA version: I8190NXXAMG1 CSC version: I8190NOXAAMG1 SW version: I8190NXXAMG1 Phone IMEI: 354785058686278 Phone SN: R21D3B1NDNP Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Phone is Rooted Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... |
06-07-2014, 17:07 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please make Factory Reset, re-flash the phone and try to repeat operation. Also try to use other Samsung Micro UART C3300k/C3303k cable with 523-525 kOhm resistor inside, most likely, the problem is with cable. |
