02-13-2015, 18:40 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | I8200 after flash big problem deadd:( INFO : 12/02/2015 20:43:24 > 1. Disconnect USB cable from phone. INFO : 12/02/2015 20:43:24 > 2. Go to Menu->Settings->More->About Device. INFO : 12/02/2015 20:43:24 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 12/02/2015 20:43:24 > 4. Go to Menu->Settings->More->Developer options. INFO : 12/02/2015 20:43:24 > 5. Turn on "USB Debugging" option. INFO : 12/02/2015 20:43:34 > Selected firmware file: I8200XXUANC1_I8200OJVANB1_ACR_Saudi_Arabia_Android _4.2.2.oct WARN : 12/02/2015 20:43:35 > Please put the phone into Download Mode and connect USB cable. WARN : 12/02/2015 20:43:35 > To put GT-I8200 into Download Mode, You have to perform the following steps: WARN : 12/02/2015 20:43:35 > 1. Reconnect the battery. WARN : 12/02/2015 20:43:35 > 2. Press and hold "Volume-" +"Power"+''Home" keys. INFO : 12/02/2015 20:43:35 > Found phone on INFO : 12/02/2015 20:43:35 > Firmware write started. INFO : 12/02/2015 20:43:35 > Writing TIMH section... INFO : 12/02/2015 20:43:38 > TIMH section has been written successfully. INFO : 12/02/2015 20:43:38 > Writing OBM section... INFO : 12/02/2015 20:43:40 > OBM section has been written successfully. INFO : 12/02/2015 20:43:40 > Writing DTim.Recovery section... INFO : 12/02/2015 20:43:42 > DTim.Recovery section has been written successfully. INFO : 12/02/2015 20:43:42 > Writing LOKE_2ND section... INFO : 12/02/2015 20:43:44 > LOKE_2ND section has been written successfully. INFO : 12/02/2015 20:43:44 > Writing DTim.Primary section... INFO : 12/02/2015 20:43:46 > DTim.Primary section has been written successfully. INFO : 12/02/2015 20:43:46 > Writing LOKE_1ST section... INFO : 12/02/2015 20:43:48 > LOKE_1ST section has been written successfully. INFO : 12/02/2015 20:43:48 > Writing PARAM section... INFO : 12/02/2015 20:43:50 > PARAM section has been written successfully. INFO : 12/02/2015 20:43:50 > Writing KERNEL section... INFO : 12/02/2015 20:43:53 > KERNEL section has been written successfully. INFO : 12/02/2015 20:43:53 > Writing RECOVERY section... INFO : 12/02/2015 20:43:57 > RECOVERY section has been written successfully. INFO : 12/02/2015 20:43:57 > Writing SYSTEM section... INFO : 12/02/2015 20:46:35 > SYSTEM section has been written successfully. INFO : 12/02/2015 20:46:35 > Writing MODEM section... INFO : 12/02/2015 20:46:40 > MODEM section has been written successfully. INFO : 12/02/2015 20:46:40 > Writing CACHE section... INFO : 12/02/2015 20:46:53 > CACHE section has been written successfully. INFO : 12/02/2015 20:46:53 > Writing HIDDEN section... INFO : 12/02/2015 20:46:57 > HIDDEN section has been written successfully. INFO : 12/02/2015 20:46:58 > Firmware writing successfully completed. INFO : 12/02/2015 20:48:50 > Selected firmware file: I8200XXUANF2_I8200OJVANF1_I8200XXUANF1_HOME.oct WARN : 12/02/2015 20:48:52 > Please put the phone into Download Mode and connect USB cable. WARN : 12/02/2015 20:48:52 > To put GT-I8200 into Download Mode, You have to perform the following steps: WARN : 12/02/2015 20:48:52 > 1. Reconnect the battery. WARN : 12/02/2015 20:48:52 > 2. Press and hold "Volume-" +"Power"+''Home" keys. INFO : 12/02/2015 20:49:02 > Found phone on INFO : 12/02/2015 20:49:02 > Firmware write started. INFO : 12/02/2015 20:49:02 > Writing TIMH section... INFO : 12/02/2015 20:49:04 > TIMH section has been written successfully. INFO : 12/02/2015 20:49:04 > Writing OBM section... INFO : 12/02/2015 20:49:06 > OBM section has been written successfully. INFO : 12/02/2015 20:49:06 > Writing DTim.Recovery section... INFO : 12/02/2015 20:49:08 > DTim.Recovery section has been written successfully. INFO : 12/02/2015 20:49:08 > Writing LOKE_2ND section... INFO : 12/02/2015 20:49:10 > LOKE_2ND section has been written successfully. INFO : 12/02/2015 20:49:10 > Writing DTim.Primary section... INFO : 12/02/2015 20:49:12 > DTim.Primary section has been written successfully. INFO : 12/02/2015 20:49:12 > Writing LOKE_1ST section... INFO : 12/02/2015 20:49:14 > LOKE_1ST section has been written successfully. INFO : 12/02/2015 20:49:14 > Writing PARAM section... INFO : 12/02/2015 20:49:17 > PARAM section has been written successfully. INFO : 12/02/2015 20:49:17 > Writing KERNEL section... INFO : 12/02/2015 20:49:20 > KERNEL section has been written successfully. INFO : 12/02/2015 20:49:20 > Writing RECOVERY section... INFO : 12/02/2015 20:49:23 > RECOVERY section has been written successfully. INFO : 12/02/2015 20:49:23 > Writing SYSTEM section... INFO : 12/02/2015 20:52:02 > SYSTEM section has been written successfully. INFO : 12/02/2015 20:52:02 > Writing MODEM section... INFO : 12/02/2015 20:52:08 > MODEM section has been written successfully. INFO : 12/02/2015 20:52:08 > Writing CACHE section... INFO : 12/02/2015 20:52:21 > CACHE section has been written successfully. INFO : 12/02/2015 20:52:21 > Writing HIDDEN section... INFO : 12/02/2015 20:52:25 > HIDDEN section has been written successfully. INFO : 12/02/2015 20:52:25 > Firmware writing successfully completed. Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\12-02-2015_20-43-08.log" closed (12/02/2015 20:54:27). i8200 AFTER FLASH BRICKED checking flash memory pass bla bla bla i try with diferent firmware I8200 not phone NOT DECLTED IN DOWNLOAD MODE WHYYYYY i flash many phone i8200 without problem and this is the first problem i8200 |
02-13-2015, 18:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | There can be many reasons of this problem: maybe, You have downgraded firmware, or firmware, that You have written is not suitable to your device revision or, maybe, your device has HW issues. |
02-13-2015, 19:15 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
02-13-2015, 19:19 | #5 (permalink) |
Member: 39250 Status: Offline Thanks Meter: 64 | i flash it phone just to change languages, when i see phone dont power correctly i try with the 2 firmware phone not power correctly , now phone is dead no power ON, all firmware is new 4.2.2 , I DONT KNOW WHYY PHONE NOT POWER i flash more than 30 pcs with this why ???? What i do to repair it now ???? |
02-14-2015, 09:38 | #8 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1970633 Status: Offline Thanks Meter: 15 | If phone don't go in download mode you can buy a jig unbrick usb. Is a small micro usb connector whit a resistor that when you put on powered off phone, this turn on in download mode.i use it in a lot of model for unbrick https://www.youtube.com/watch?v=Rdn5GoRjhn0 i buy on ebay |
The Following User Says Thank You to Caoss For This Useful Post: |
