08-31-2014, 22:57 | #1 (permalink) |
Crazy Poster Join Date: Oct 2010
Member: 1418068 Status: Offline Thanks Meter: 2 | I8200n big problem.............. Code: Platform: Samsung Android Selected port: COM10 Selected model: GT-I8200N Searching for a phone. Please wait... ADB server killed. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Firmware compiled date: Fri Jan 24 18:47:43 KST 2014 PDA version: I8200NXXUANAD CSC version: I8200NOXAANAD SW version: I8200NXXUANAD Phone IMEI: 359919054417934 Phone SN: R21F66CR4PL Android version: 4.2.2 (JDQ39) Unlocking phone... Cheking Root Phone is rooted Deactivating MSL... Please insert card into phone, if phone is locked, then type 00000000 Phone is successfully unlocked |
09-01-2014, 04:48 | #3 (permalink) |
Freak Poster Join Date: May 2009 Location: Bangladesh
Member: 1024699 Status: Offline Sonork: 100.1622959 Thanks Meter: 600 | When ask code again try 00000000.....when it not accept the first time 00000000, re enter it again some new security phone after unlock still lock flash other fiemware hope ur problem solved...... |
09-01-2014, 06:49 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to do the next: 1. install the latest Software version (Software). 2. Take out SIM and SD cards from the phone. 3. Re-flash the phone. 4. Make Factory data reset. 5. Make Unlock again. 6. Re-start the phone via phone's menu (via "Power ON" button, don't disconnect the battery). 7. Insert SIM card and write here the result. Try to repeat the Unlock operation several times. |
09-01-2014, 11:32 | #5 (permalink) | |
Member: 1418068 Status: Offline Thanks Meter: 2 | thanx for reply i have donr same thing like u said..but at the end when i make data reset again then after restart it ask again code.... plz help Quote:
09-01-2014, 11:58 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please upload log and logx files of "Write Firmware" and "Unlock" operations and post here links. We will check where can be the problem. |
09-01-2014, 12:04 | #7 (permalink) | ||
Member: 1418068 Status: Offline Thanks Meter: 2 | i did flash with odin software.....when i try to flash with octopus it doesn't connect with usb......but octopus software connect usb while unloking.. why it dosnt connect usb while flashing//?? Quote:
09-01-2014, 12:39 | #8 (permalink) |
Member: 1418068 Status: Offline Thanks Meter: 2 | when i press write firmware then connecting and disconnecting sound comes from laptop speaker after every 2 secnds connecting disconnecting and still searching fone..when i press cancel button then conectivity sound doesn't come....it meanx this fone cant b flash with octopus.but it does flash with odin.. i have 11 fones it doing same thing with every fone....i have changed pc and windows but same thing plz solve my problm as soon as possible thnx |
09-01-2014, 12:50 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Upload *.logx file of the operations and post here link. This file can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder and has the same title as *.log file. |
09-02-2014, 11:12 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Run the Octoplus Samsung Software. 3. Take out SIM and SD cards from the phone. 4. Re-flash the phone with the firmware "I8200NXXUANC1_I8200NVFGANB2_VD2_Germany(Vodafone) _Android_4.2.2". 5. Perform the "Unlock" operation. 6. Close the Software. 7. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here links, we will check, where can be the problem with the device. |
09-02-2014, 16:04 | #13 (permalink) |
Member: 1418068 Status: Offline Thanks Meter: 2 | it is not connecting with usb.........odin can but not octopus when i press write firmware it just says searching fone and in device manage all things appears then disappear when i press cancell button then ..then stop all things in device manager..u can take teamvewiwer.... Last edited by newazan; 09-02-2014 at 16:10. |
09-02-2014, 16:07 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Contact us right now to Skype, ICQ or Yahoo! Messenger, we will look remotely; our contacts You can find in our profile. |
