06-09-2014, 15:04 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: ...
Member: 824361 Status: Offline Thanks Meter: 25 | I8200N root [Solved] for repair imei --------------------------------------------------- Platform: Samsung Android Selected port: COM411 Selected model: GT-I8200N Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Mar 3 16:31:32 KST 2014 PDA version: I8200NXXUANC1 CSC version: I8200NOXXANC1 SW version: I8200NXXUANC1 Phone IMEI: 001068000000006 Phone SN: R21F50CSH5P Android version: 4.2.2 (JDQ39) Old IMEI: 001068-00-000000-6 New IMEI: 359929-15-079983-0 Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Write IMEI failed Last edited by Octopus box; 09-23-2014 at 06:40. |
06-09-2014, 15:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | The problem not only with root. There is some issue with Repair IMEI operation for this device. We work to fix the problem. As soon as we will prepare test Software version, we will contact You. This can occupy 2-3 days. |
07-08-2014, 19:53 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: England
Member: 193192 Status: Offline Thanks Meter: 327 | Still not fixed Octopus team. I just tried to unlock i8200N v4.2.2 and still unlock not working. "Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation." Flash files for unlock also do not exist on support site. Where is solution you promised that does not require rooting? If solution does not exist please remove phone from current supported unlocking models. BTW vRoot and Kingo and zroot do not work either on this phone. |
07-08-2014, 19:57 | #4 (permalink) | |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | Quote:
root, and install busybox and try again | |
The Following User Says Thank You to Maurioski For This Useful Post: |
07-10-2014, 14:54 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to re-flash the phone with different firmwares and try to root the device with each of them, maybe, with some firmware will be possible to root the device by using TowelRoot (or by using the latest versions of VRoot, Kingo Root softwares). |
