06-11-2014, 06:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | i8260L Problem Can help me plz I a new user of Octopus Samsung, but I not have luck with this activation. My problem: I try to repair imei on a i8260L but now the phone not detect a simcard. How I make wrong ? Support can help me please ? Many thanks |
06-11-2014, 07:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Do the next: 1. Install the latest Software version (Software) 2. Root the phone by using the latest versions of VRoot, Kingo Root or Impactor Softwares. 3. Turn on USB Debugging Mode in the phone. 4. Perform the Repair IMEI operation. 5. Post here full Software log with all of your actions. |
06-11-2014, 08:17 | #5 (permalink) | |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Quote:
Im going to be crazy with this phone ! I use the last sw version. I flashed the phone 5 times. 1 time with this firm: GT-I8260L_for_IMEI_Repair.oct I repair ok but not detected simcard After: Flashed again with this firm: I8260XXAMG3_I8260LUXAMG1_I8260XXAMG4_HOME.oct Always get error with a ¨computer & triangle¨ the phone turn on. I rooted in this time with kingoRoot but now get this error: ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM171 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 353235-05-037430-0 New IMEI: 353235-05-037431-8 Searching for a phone. Please wait... Firmware compiled date: Wed Jul 17 14:46:59 KST 2013 PDA version: I8260XXAMG3 CSC version: Unknown SW version: I8260LUBAMG2 Phone IMEI: 353235050374300 Phone SN: RV1D84PCYTP Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Write IMEI failed Never ask me to ¨Allow¨ on Root | |
06-11-2014, 08:26 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You device is not rooted correctly. Try to do the next: 1. Write firmware "GT-I8260L_for_IMEI_Repair.oct". 2. Perform the Repair IMEI operation. When Software will ask, press "Allow" button on the phone's screen every time when superuser dialog window appears. If the SU dialog window will not appears, run the SU app manually in the phone. 3. Post here full Software log (with operations of Write Firmware and Repair IMEI ). |
06-11-2014, 09:11 | #7 (permalink) | |
When finished look like this: (see pics) and not turn on How I make now ? | |
06-11-2014, 09:48 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please look here, maybe this will help: http://forum.gsmhosting.com/vbb/f684...1/#post9988769. Try to write firmware "I8260XXAMG3_I8260LUXAMG1_I8260XXAMG4_HOME.oct " from the Support Area, then root the phone by using "Framaroot-1.8.0" Software from the Support Area and then make Unlock. Last edited by Octopus box; 06-11-2014 at 09:54. |
06-11-2014, 10:05 | #9 (permalink) | |
No get network and not detect simcard. This model is too difficult ? Thanks | |
06-11-2014, 10:18 | #11 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | Unlock Log Welcome to Octoplus/Octopus Box Samsung software version 1.5.8 ----------------------------------------------------------------------------------- To connect GT-I8260L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM171 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 Phone IMEI: 353235-05-03xxxx-x SW version: 8X25-SSOSKOLYM-2035 Unlocking phone... Phone is successfully unlocked Repair imei Log: Welcome to Octoplus/Octopus Box Samsung software version 1.5.8 ----------------------------------------------------------------------------------- To connect GT-I8260L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM171 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 Phone IMEI: 353235-05-037431-8 SW version: 8X25-SSOSKOLYM-2035 Unlocking phone... Phone is successfully unlocked ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM171 Selected model: GT-I8260L Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM4 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM171 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 Phone IMEI: 353235-05-037431-8 SW version: 8X25-SSOSKOLYM-2035 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM171 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 353235-05-037431-8 New IMEI: 353235-05-037431-8 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM171 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 353235-05-xxxxxx-x New IMEI: 353235-05-xxxxx2-6 Searching for a phone. Please wait... Firmware compiled date: Wed Jul 17 14:46:59 KST 2013 PDA version: I8260XXAMG3 CSC version: Unknown SW version: I8260LUBAMG2 Phone IMEI: 35323505xxxxxxx Phone SN: RV1D84PCYTP Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Network is successfully repair. Repairing IMEI ... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) here is the logs but the problem is what not detect simcard |
06-11-2014, 10:20 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Is your phone unlocked? Make Unlock, then insert SIM card, wait 3-5 minutes and try to find and select network manually. |
06-11-2014, 10:29 | #13 (permalink) | |
I show the log of the unlock procedure. The phone is turned on with a simcard inside, show signal but Only Emergency Calls (not simcard) | |
06-11-2014, 10:33 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to use other SIM cards. Also try to insert motorola test card and write whether the phone detects card. And note, You shouldn't write any firmware after performing Repair IMEI operation. If You will write firmware, You need to perform Repair IMEI operation again. |
06-11-2014, 10:53 | #15 (permalink) | |
The signal is full and for a moment get a circle (go out) and comes again. The only problem is that not detect the sim. Yes, I understand that I need to repair imei after write firmware. I dont know how much I make | |
