10-21-2014, 22:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ARG - AZUL
Member: 226845 Status: Offline Thanks Meter: 78 | I8260l write imei failed [Solved] Phone was rooted with kingo, vroot too. ADB shell is permanetly accepted by SU (no messages appears on window to be "allowed" during process) What to do now? PLS see: Code: Welcome to Octoplus/Octopus Box Samsung software version 1.7.1 ----------------------------------------------------------------------------------- To connect GT-I8260L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM458 Selected model: GT-I8260L Reading info, please wait... Detected phone model: GT-I8260L Firmware compiled date: Tue Jul 30 16:10:12 KST 2013 PDA version: I8260LUBAMG3 CSC version: I8260LUUBAMH1 SW version: I8260LUBAMG2 Phone IMEI: 385922083450098 Phone SN: RV1F10PPLEA Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM458 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 SW version: 8X25-SSOSKOLYM-2035 Old IMEI: 385922-08-345009-8 New IMEI: 388922-08-345009-5 Searching for a phone. Please wait... Firmware compiled date: Tue Jul 30 16:10:12 KST 2013 PDA version: I8260LUBAMG3 CSC version: I8260LUUBAMH1 SW version: I8260LUBAMG2 Phone IMEI: 385922083450098 Phone SN: RV1F10PPLEA Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Repairing network... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Write IMEI failed Last edited by Octopus box; 10-23-2014 at 13:22. |
10-22-2014, 06:50 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Quote:
10-22-2014, 12:37 | #6 (permalink) |
Member: 226845 Status: Offline Thanks Meter: 78 | as I told u I used Vroot, kingo, and all the SU requests were permanently accepted. see log, firstly Octopus detects phone as "ROOTED", then it cannot resolve next step because of the negative to access "without root privileges"... its a contradiction. |
10-22-2014, 13:58 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Take our SIM and SD cards from the phone. 3. Root the phone. 4. Perform the "Repair IMEI" operation again. 5. Close the Software. 6. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here links, we will check, where can be the problem with the device. |
10-22-2014, 20:52 | #9 (permalink) | |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | ok, this is the thing, follow this steps, 1.- Download "GT-I8260L_for_IMEI_Repair.oct" from Support, and Flash with Octopus box 2.- the phone "DIE" (don't scare) 3.- use Odin and install the next firmware "I8260XXAMG3_I8260LUXAMG1_I8260XXAMG4_HOME.tar.md5 " 4.- Odin in this step "Fail", yst restart the cellphone, 5.- Quote:
10-22-2014, 21:14 | #10 (permalink) | |
Member: 226845 Status: Offline Thanks Meter: 78 | Quote:
Clean software 4.1.2, then rooted with Frama: again failed, here ar ur links: https://www.sendspace.com/file/lmc6fa https://www.sendspace.com/file/ncmbfh | |
10-22-2014, 21:17 | #11 (permalink) | |
10-23-2014, 13:19 | #13 (permalink) | |
Member: 226845 Status: Offline Thanks Meter: 78 | After much times of testing different ways, finally done by Maurioski´s way, but with little mods: Quote:
The Following User Says Thank You to FREEGuille For This Useful Post: |
