02-05-2016, 15:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 51
Member: 69514 Status: Offline Thanks Meter: 66 | I9003 force stop Normal formatting hard reset & soft reset didn't solved it. How to solve it? |
02-05-2016, 15:42 | #2 (permalink) | |
No Life Poster Join Date: Jun 2013 Location: mumbai Age: 35
Member: 1969619 Status: Offline Sonork: 100.1670362 QQ3052215670 Thanks Meter: 1,587 | Quote:
it just coz of monkey virus just flash ur device and after flash if data has not delete just format your problem will be solve | |
02-05-2016, 16:16 | #4 (permalink) | |
i think product supporter will not guide this coz its normal problem with all phones the only solution is flash if u are getting any error in flashing then i m sure product supporter will guide you as u wish but only flash can help you if done after flash just press thanx | |
02-05-2016, 16:40 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. If after Factory Reset problem remains the same - try to reflash the phone. Also, try to change google account and check whether problem remains. Firmwares for GT-I9003 are available in the Support Area. To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. |
02-05-2016, 18:45 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to force stop Play Store from Application manager, then launch it again. If problem will remain the same - try to write different firmwares one by one. Currently no other solution. |
