04-20-2016, 17:46 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Bangladesh
Member: 782943 Status: Offline Sonork: 100.1601067 Thanks Meter: 204 | I9070 after update restarting with error kernel panic I flashed with another file too but problem not solved. Please help me too solve this problem. Thanks in advance Br Rasel |
04-20-2016, 18:24 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try to make Factory Reset and Wipe cache partition from Recovery Mode, then try to reflash the phone with "i9070jvbmd1_i9070ojvbmd1_xsg_united_arab_emirates _android_4.1.2" firmware from the Support Area. Post here result and full Software log of the operation. |
04-21-2016, 17:21 | #3 (permalink) | |
Member: 782943 Status: Offline Sonork: 100.1601067 Thanks Meter: 204 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect GT-I9070 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 8. Press Home button. 9. Press "Read Info" in software. Selected firmware file: I9070JVBMD1_I9070OJVBMD1_XSG_United_Arab_Emirates_ Android_4.1.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9070 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing CACHEFS section... CACHEFS section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing Kernel2 section... Kernel2 section has been written successfully. Writing Kernel section... Kernel section has been written successfully. Writing Modem section... Modem section has been written successfully. Writing SBL section... SBL section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing PWR MGT section... PWR MGT section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version | |
