07-18-2014, 07:52 | #2 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Chittagong Age: 35
Member: 1188409 Status: Offline Sonork: 100.1616589 Thanks Meter: 270 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9070 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 8. Press Home button. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM4 Selected model: GT-I9070 Searching for a phone. Please wait... Detected phone model: GT-I9070 Detect Model Name: GT-I9070 S/W version: I9070VJLD1 Phone IMEI: none ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM4 Selected model: GT-I9070 Searching for a phone. Please wait... Detected phone model: GT-I9070 Detect Model Name: GT-I9070 S/W version: I9070VJLD1 Phone IMEI: none Old IMEI: Unknown New IMEI: 351524-05-****7-6 Writing new IMEI. Please wait... Deactivating MSL... MSL deactivate successfully IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
07-18-2014, 07:55 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
To repair baseband, try to re-flash the phone with different firmwares, which You have. No other way how to repair baseband. And only then (when baseband will be correct), make Repair IMEI. | |
07-18-2014, 08:02 | #4 (permalink) |
Member: 1188409 Status: Offline Sonork: 100.1616589 Thanks Meter: 270 | if i flash this phone with low verson 2.3.6 or higher verson witch on corect for this phone to back baseband pls help me sir also can i flash it with odin or octopus (with suport file) help me pls |
07-18-2014, 08:16 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | It is impossible to say, which firmware will help to solve the problem with baseband exactly, try to write different firmwares one by one. You can write firmware by using Octopus/Octoplus Sasmung Software or any other tool, that supports this device. |
