12-19-2013, 09:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | i9100 connection failed or invalid mmi code Previous phone version was android ver : 2.3.3 Baseband Ver : i9100XXKF1 Kernel Ver : 2.6.35.7-i9100JPKF-CL303619 root@Dell101 #2 Build Num: Gingerbread.JPKF3 Then i update the phone with I9100XXLP6_OXXLP3_Android_4.0.3.oct this file. after update network function is not working. When i make call it show "Connection problem or invalid MMi code" Then i repair efs and also repair imei and SL number and make Repair NVM. But same problem. Call function is not working. Then again i downgrade the phone from 4.0.3 to 2.3.3 with its orginal firmware. But same problem now. Here is the log : Code: Welcome to Octoplus/Octopus Box Samsung software version 1.4.2 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 To put GT-I9100 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... Phone found EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 2.3.3 (GINGERBREAD) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Detected phone model: GT-I9100 Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 PDA Version: I9100JPKF3 CSC Version: I9100OJPKF2 SW Version: I9100XXKF1 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 2.3.3 (GINGERBREAD) Checking Root: Phone is not Rooted. Rooting phone... Rooting phone failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 ADB server killed. Detected phone model: GT-I9100 Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 PDA Version: I9100JPKF3 CSC Version: I9100OJPKF2 SW Version: I9100XXKF1 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 2.3.3 (GINGERBREAD) Checking Root: Phone is Rooted. Erasing old IMEI. It can take some time. Please wait... Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM3 Phone connected successfully Writing new phone IMEI... IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 Phone IMEI: 358913040997613 Phone SN: 00000000000 Android version: 2.3.3 (GINGERBREAD) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 Phone IMEI: 358913040997613 Phone SN: 00000000000 Android version: 2.3.3 (GINGERBREAD) But same problem. Please suggest me what should i do now? |
12-21-2013, 07:58 | #3 (permalink) | |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Quote:
I do it but same position Code: Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 Phone IMEI: 358913040997613 Phone SN: R21CC6EXMXJ Android version: 2.3.3 (GINGERBREAD) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 Phone IMEI: 358913040997613 Phone SN: R21CC6EXMXJ Android version: 2.3.3 (GINGERBREAD) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Jun 20 17:48:34 KST 2011 Phone IMEI: 358913040997613 Phone SN: R21CC6EXMXJ Android version: 2.3.3 (GINGERBREAD) Unlocking phone... Phone is successfully unlocked | |
12-21-2013, 09:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to make Factory data reset and wipe cache partition; then re-flash the phone again. Try to write different firmwares one by one and check whether the problem still exists. |
12-24-2013, 07:50 | #5 (permalink) | |
I am also sorry if i bored u , this strange problem pain me. I am also trying to update different firmware. flash with Odin with different firmware and update ver like 4.0.3, 4.1 or 4.1.2. Do u suggest me a firmware file name....... | |
12-24-2013, 07:55 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
1. Read EFS and Security backups. 2. Repair EFS and check whether network is available (active). If network is available - try to perform Repair IMEI operation and check network again. Last edited by Octopus box; 12-24-2013 at 15:08. | |
