03-07-2014, 10:35 | #1 (permalink) |
Major Poster Join Date: Sep 2010 Location: baskom
Member: 1384861 Status: Offline Thanks Meter: 0 | i9100 Imei NULL my i9100 SII IMEI NULL use android 4.0.3 Welcome to Octoplus/Octopus Box Samsung software version 1.4.3 ----------------------------------------------------------------------------------- To connect GT-I9100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Searching for a phone. Please wait... ADB server killed. Phone found. Firmware compiled date: Thu Jan 5 23:21:30 KST 2012 PDA Version: I9100XXKPA CSC Version: I9100OXAKPA PDA Version: Unknown Phone IMEI: Unknown Android version: 4.0.3 (ICS) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9100 Detected phone model: GT-I9100 Firmware compiled date: Thu Jan 5 23:21:30 KST 2012 PDA Version: I9100XXKPA CSC Version: I9100OXAKPA PDA Version: Unknown Phone IMEI: Unknown Android version: 4.0.3 (ICS) Checking Root: Phone is Rooted. Erasing old IMEI. It can take some time. Please wait... Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Write IMEI failed |
03-07-2014, 10:42 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As You can see from this Software log, modem part is damaged in your device: Quote:
At first, try to re-flash the device with different firmwares and check whether modem is correct (not Unknown) and only then (when phone's modem part will be correct) try to perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. Don't forget to install the latest Software version (Octopus Box Downloads - Software, Drivers, Manual). | |
03-07-2014, 15:02 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Of course, the same. As I have written above, it is not possible to repair IMEI, if phone's modem part is damaged. In your device modem part is still damaged: Quote:
