05-28-2014, 10:13 | #1 (permalink) |
Junior Member Join Date: Feb 2014 Location: pilipinas
Member: 2122425 Status: Offline Thanks Meter: 1 | I9100t null imei repair problem here my logs [CODE]Welcome to Octoplus/Octopus Box Samsung software version 1.4.5 ----------------------------------------------------------------------------------- To connect GT-I9100T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9100T Reading info, please wait... Detected phone model: GT-I9100T Firmware compiled date: Mon Nov 28 21:24:55 KST 2011 PDA version: I9100TDCKK3 CSC version: I9100TTHLKK1 SW version: Unknown Phone IMEI: Unknown Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9100T Detected phone model: GT-I9100T Firmware compiled date: Mon Nov 28 21:24:55 KST 2011 PDA version: I9100TDCKK3 CSC version: I9100TTHLKK1 SW version: Unknown Phone IMEI: Unknown Android version: 2.3.6 (GINGERBREAD) Checking Root: Phone is Rooted. Erasing old IMEI. It can take some time. Please wait... Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Go to dial window. 3. Enter *#7284# number. 4. Set "UART" radio button to "MODEM" value. 5. Connect phone via UART cable to Box. Connecting to phone, please wait... Write IMEI failed how to repair this need good efs i9100t tnx.......... |
05-28-2014, 10:17 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from this Software log, modem part is damaged in your device: Quote:
At first, try to re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) make Repair EFS and perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
