07-19-2014, 04:23 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2008 Location: California USA
Member: 743601 Status: Offline Sonork: 83392409 Thanks Meter: 138 | I9103 imei + baseband repair Proper Procedure here remove battery tapos press home botton together with volume down for 10 secs or use apx boot repair so i flashed firmware using octopus flash your i9103 with 4.0.4 version download this file I9103XXLQ7_I9103DRELP3_DRE after i download i use octopus firmware converter then use this tool for easy rooting VOLCANO after rooting after flashed apx complete you will get imei Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM91 Selected model: GT-I9103 Detected phone model: GT-I9103 HW Version: XXXXXXXXXXXXXX Phone IMEI: 359148-04-112221-3 Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM91 Detected phone model: GT-I9103 HW Version: XXXXXXXXXXXXXX Phone IMEI: 359148-04-112221-3 Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed No diagnostic ports found! Connecting to phone on COM3 Phone connection failed Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM91 Selected model: GT-I9103 Detected phone model: GT-I9103 HW Version: XXXXXXXXXXXXXX Phone IMEI: 359148-04-112221-3 Firmware compiled date: Tue Aug 7 14:57:37 KST 2012 PDA version: I9103XXLQ7 CSC version: I9103DRELP3 SW version: I9103XXLQ3 Phone IMEI: 359148041122213 Phone SN: 00000000000 Android version: 4.0.4 (IMM76D) Repairing Serial Number. It can take some time. Please wait... Phone will restart now SN repaired successfully. ok na po ang unit may signal hindi na namamatay other logs here yung other logs po ito Platform: Samsung Android INFO : 7/15/2014 9:28:24 AM > Selected port: COM91 INFO : 7/15/2014 9:28:24 AM > Selected model: GT-I9103 INFO : 7/15/2014 9:28:24 AM > Repairing... WARN : 7/15/2014 9:28:24 AM > To connect GT-I9103 phone, please perform the following steps: WARN : 7/15/2014 9:28:24 AM > 1. Reconnect phone battery. WARN : 7/15/2014 9:28:24 AM > 2. Press and hold "Volume UP"+"Home" for 10 second. WARN : 7/15/2014 9:28:24 AM > 3. Insert USB cable. INFO : 7/15/2014 9:28:24 AM > Searching phone... INFO : 7/15/2014 9:32:12 AM > Phone found. INFO : 7/15/2014 9:32:12 AM > Sending loaders... INFO : 7/15/2014 9:32:36 AM > Loader send successfuly. INFO : 7/15/2014 9:32:36 AM > Creating Boot Config Table section INFO : 7/15/2014 9:32:37 AM > Section Boot Config Table creat successfully INFO : 7/15/2014 9:32:37 AM > Creating Partition Table section INFO : 7/15/2014 9:32:37 AM > Section Partition Table creat successfully INFO : 7/15/2014 9:32:37 AM > Creating Fastboot section INFO : 7/15/2014 9:32:37 AM > Section Fastboot creat successfully INFO : 7/15/2014 9:32:37 AM > Creating Master Boot Record section INFO : 7/15/2014 9:32:37 AM > Section Master Boot Record creat successfully INFO : 7/15/2014 9:32:37 AM > Creating System section INFO : 7/15/2014 9:32:37 AM > Section System creat successfully INFO : 7/15/2014 9:32:37 AM > Creating EFS section INFO : 7/15/2014 9:32:37 AM > Section EFS creat successfully INFO : 7/15/2014 9:32:37 AM > Creating SOS section INFO : 7/15/2014 9:32:37 AM > Section SOS creat successfully INFO : 7/15/2014 9:32:37 AM > Creating Linux kernel section INFO : 7/15/2014 9:32:37 AM > Section Linux kernel creat successfully INFO : 7/15/2014 9:32:37 AM > Creating APP section INFO : 7/15/2014 9:32:37 AM > Section APP creat successfully INFO : 7/15/2014 9:32:37 AM > Creating CAC section INFO : 7/15/2014 9:32:37 AM > Section CAC creat successfully INFO : 7/15/2014 9:32:37 AM > Creating MSC section INFO : 7/15/2014 9:32:37 AM > Section MSC creat successfully INFO : 7/15/2014 9:32:37 AM > Creating MDM section INFO : 7/15/2014 9:32:37 AM > Section MDM creat successfully INFO : 7/15/2014 9:32:37 AM > Creating User data A section INFO : 7/15/2014 9:32:37 AM > Section User data A creat successfully INFO : 7/15/2014 9:32:37 AM > Creating OTA section INFO : 7/15/2014 9:32:37 AM > Section OTA creat successfully INFO : 7/15/2014 9:32:37 AM > Creating HID section INFO : 7/15/2014 9:32:37 AM > Section HID creat successfully INFO : 7/15/2014 9:32:37 AM > Creating GPT section INFO : 7/15/2014 9:32:37 AM > Section GPT creat successfully INFO : 7/15/2014 9:32:37 AM > Formating Boot Config Table section INFO : 7/15/2014 9:32:37 AM > Section Boot Config Table format successfully INFO : 7/15/2014 9:32:37 AM > Formating Partition Table section INFO : 7/15/2014 9:32:37 AM > Section Partition Table format successfully INFO : 7/15/2014 9:32:37 AM > Formating Fastboot section INFO : 7/15/2014 9:32:37 AM > Section Fastboot format successfully INFO : 7/15/2014 9:32:37 AM > Formating Master Boot Record section INFO : 7/15/2014 9:32:37 AM > Section Master Boot Record format successfully INFO : 7/15/2014 9:32:37 AM > Formating System section INFO : 7/15/2014 9:32:38 AM > Section System format successfully INFO : 7/15/2014 9:32:38 AM > Formating EFS section INFO : 7/15/2014 9:32:38 AM > Section EFS format successfully INFO : 7/15/2014 9:32:38 AM > Formating SOS section INFO : 7/15/2014 9:32:38 AM > Section SOS format successfully INFO : 7/15/2014 9:32:38 AM > Formating Linux kernel section INFO : 7/15/2014 9:32:38 AM > Section Linux kernel format successfully INFO : 7/15/2014 9:32:38 AM > Formating APP section INFO : 7/15/2014 9:32:39 AM > Section APP format successfully INFO : 7/15/2014 9:32:39 AM > Formating CAC section INFO : 7/15/2014 9:32:40 AM > Section CAC format successfully INFO : 7/15/2014 9:32:40 AM > Formating MSC section INFO : 7/15/2014 9:32:40 AM > Section MSC format successfully INFO : 7/15/2014 9:32:40 AM > Formating MDM section INFO : 7/15/2014 9:32:40 AM > Section MDM format successfully INFO : 7/15/2014 9:32:40 AM > Formating User data A section INFO : 7/15/2014 9:32:41 AM > Section User data A format successfully INFO : 7/15/2014 9:32:41 AM > Formating OTA section INFO : 7/15/2014 9:32:41 AM > Section OTA format successfully INFO : 7/15/2014 9:32:41 AM > Formating HID section INFO : 7/15/2014 9:32:42 AM > Section HID format successfully INFO : 7/15/2014 9:32:42 AM > Formating GPT section INFO : 7/15/2014 9:32:42 AM > Section GPT format successfully INFO : 7/15/2014 9:32:45 AM > Updating data, plaese wait... INFO : 7/15/2014 9:33:00 AM > Updating data successfully completed. WARN : 7/15/2014 9:33:07 AM > Phone successfuly repair, please write firmware, make Factory reset and enter corect IMEI INFO : 7/15/2014 9:33:07 AM > Phone repair successfuly INFO : 7/15/2014 9:33:48 AM > Firmware conversion started for phone INFO : 7/15/2014 9:33:48 AM > Firmware conversion started for GT-I9103 phone INFO : 7/15/2014 9:35:25 AM > Firmware converted successfully INFO : 7/15/2014 9:36:33 AM > Selected firmware file: I9103XXLQ7_I9103DRELP3_I9103XXLQ3_HOME.oct WARN : 7/15/2014 9:36:40 AM > Please switch your phone to the download mode and connect it to a PC. WARN : 7/15/2014 9:36:40 AM > To put GT-I9103 phone into download mode you have to perform the following steps: WARN : 7/15/2014 9:36:40 AM > 1. Reconnect phone battery. WARN : 7/15/2014 9:36:40 AM > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 7/15/2014 9:36:40 AM > 3. When phone turns on press "Volume+" button. INFO : 7/15/2014 9:36:40 AM > Found phone on INFO : 7/15/2014 9:36:40 AM > Firmware write started. INFO : 7/15/2014 9:36:40 AM > Writing PIT section... INFO : 7/15/2014 9:37:03 AM > PIT section has been written successfully. INFO : 7/15/2014 9:37:03 AM > Writing LNX section... INFO : 7/15/2014 9:37:07 AM > LNX section has been written successfully. INFO : 7/15/2014 9:37:07 AM > Writing MDM section... INFO : 7/15/2014 9:37:12 AM > MDM section has been written successfully. INFO : 7/15/2014 9:37:12 AM > Writing CAC section... INFO : 7/15/2014 9:37:21 AM > CAC section has been written successfully. INFO : 7/15/2014 9:37:21 AM > Writing HID section... INFO : 7/15/2014 9:37:52 AM > HID section has been written successfully. INFO : 7/15/2014 9:37:52 AM > Writing APP section... INFO : 7/15/2014 9:41:30 AM > APP section has been written successfully. INFO : 7/15/2014 9:41:30 AM > Writing SOS section... INFO : 7/15/2014 9:41:34 AM > SOS section has been written successfully. INFO : 7/15/2014 9:41:36 AM > Firmware writing successfully completed. |
