04-27-2014, 14:53 | #1 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | i9152 IMEI proplem just got i9152 with damage IMEI flash it with special frimwear from support trying to fix IMEI and getting this Code: Welcome to Octoplus/Octopus Box Samsung software version 1.5.5 ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM40 Selected model: GT-I9152 Connecting to phone on COM258 Detected phone model: GT-I9152 SW version: I9152XXUAMEF/I9152ODDAMF1/I9152XXUANA1/I9152XXUAMEF HW Version: XXXXXXXXXXXXXX Firmware compiled date: Fri May 31 22:31:46 KST 2013 Phone SN: 00000000000 Android version: 4.2.2 (JDQ39) Old IMEI A: 000000-00-000000-0 New IMEI A: 358754-21-678899-2 Writing new phone IMEI A... Please write firmware from support Write IMEI failed |
04-27-2014, 16:25 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As I see, here some problems with your device. Some data are damaged in your device: Quote:
What is the problem with your device exactly? What is the state of your phone? | |
04-27-2014, 19:17 | #3 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Custmer update it via wifi and imei got damaged ..it is brand new phone trust me Sent from my SM-G7102 using Tapatalk |
04-28-2014, 11:55 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please do the next: 1. Close Octoplus Samsung Software. 2. Delete all files from folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Run Octoplus Samsung Software. 4. Re-start the phone. 5. Perform "Repair IMEI" operation again. 6. Close the Software. 7. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here links, we will research, where can be the problem with your device and write You the result. |
04-28-2014, 15:32 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As I see, from these logs, You have not written the special firmware before. Write the special firmware from the Support Area, perform steps 1-6 and post here link to new created "*.log" and "*.logx" files. |
04-29-2014, 12:04 | #9 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | seems phone updated though OTA to EFS2 i guess if there is a way to downgrade phone all will works fine |
