Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 09-10-2013, 15:42   #1 (permalink)
Member: 1841293
Sonork: nour
Thanks Meter: 13
i9190 repair imei problem [Solved]
my friends i find root for this phone in octopus support Root_GT-I9190.oct
i root the phone reset efs open usb DM+MODEM+ADB
AND used usb for repairing but all in vain and still request root
this is log help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Welcome to Octoplus/Octopus Box Samsung software version 1.2.9
Platform: Samsung Android
Selected port: COM40
Selected model: GT-I9190
Mode: Normal
Phone model: GT-I9190
Firmware compiled date: Jun 04 2013
Firmware compiled time: 17:00:00
Firmware released date: Jun 21 2013
Firmware released time: 15:02:22
SW Version: M8930B-AAAATAZM-3.2.27030
Old IMEI: 004400-15-202000-0
New IMEI: 356154-02-946783-9
Firmware compiled date: Fri Jun 21 13:43:21 KST 2013
Phone SN: RF1D67DT54P
Android version: 4.2.2 (JDQ39)
Cheking Root
Can't root Android version 4.2.2 and higer. Please Root the phone, or
flash phone using firmware with lower version of Android or rooted
firmware and repeat operation.
Can't get root privileges.
Phone is not rooted
Write IMEI failed
Old 09-10-2013, 16:17   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 21,189
Hello.
Please read carefully software log:
Cheking Root
You phone is not rooted, You need to root it manually.
Also please always read carefully software manual (press "Help" button in software) before to perform any operation:
Repair IMEI:
1. Root your phone manualy.
2. Connect powered-on phone to PC via Micro USB cable.
3. Enter correct IMEI.
4. Click "IMEI fix" button.
5. Follow software instructions (prompts).
Root:
1. Put phone into Download Mode.
2. Connect the phone to PC via Micro USB cable.
3. Install required driver.
4. Select "Root_GT-I9190.oct" firmware file.
5. Click "Write firmware" button.
6 .Copy the file "GT-I9190_RootKit_v1.zip" to the root folder of your memory card.
7. Shutdown your device.
8. Put your device into Recovery mode.
9. Select "apply update from sdcard" and choose "GT-I9190_RootKit_v1.zip".
10. Select "reboot system now".
11. After reboot phone will be rooted.
Please carefully perform all these steps to root the phone.
The Following 2 Users Say Thank You to Octopus box For This Useful Post:
Old 09-11-2013, 19:38   #3 (permalink)
Member: 1841293
Sonork: nour
Thanks Meter: 13
my friend i rooted the phone
as you told me
changed imei
but when i check imei by *#06# ifind it 0/01
and this is the log
Selected port: COM8
Mode: Normal
New IMEI: 356154-02-946361-4
Cheking Root
Erasing old IMEI. It can take some time. Please wait...
Phone will restart now. Please don't disconnect cable!
Found phone on COM8
Repairing NVM for GT-I9190 phone...
NVM repair completed successfully
New IMEI successfully written.
Please, restart the phone to apply changes
Old 09-12-2013, 07:31   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Most likely, phone's EFS is danaged. Try to read out Security and EFS from another working (with correct IMEI) GT-I9190 and write them into your device. Then make repair IMEI again.
Old 09-12-2013, 17:44   #5 (permalink)
Member: 1841293
Sonork: nour
Thanks Meter: 13
ok my friend what you have told is gold thank you very much i do as you told me and every thing is ok
you are the best
Page generated in 0.27722 seconds with 7 queries
