01-15-2017, 15:08 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | i9192 help with writing firmware ----------------------------------------------------------------------------------- To connect SM-J500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected firmware file: I9192DDUAMJ2_I9192ODDAMJ2_INU_Android_ 4.2.2_provided_by_Palash_Ahammad_(aka_NP).oct Please put the phone into Download Mode and connect USB cable. To put GT-I9192 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.4.6 Software version. Selected firmware file: I9192UBUAMF7_ZTOAMF7_Brazil_Android_ 4.2.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9192 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.4.6 Software version. Last edited by Octopus box; 01-16-2017 at 09:04. |
01-15-2017, 15:16 | #2 (permalink) |
Member: 500302 Status: Offline Thanks Meter: 157 | Performed by 2.4.6 Software version. Selected firmware file: I9192XXUCNJ3_I9192SERCNJ3_SER_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9192 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.4.6 Software version. |
01-16-2017, 09:01 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please install the latest Software version, then repeat Write Firmware operation again. Make sure that battery is full charged. |
01-17-2017, 07:24 | #5 (permalink) |
Member: 500302 Status: Offline Thanks Meter: 157 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 Selected firmware file: I9192XXUCNJ3_I9192SERCNJ3_SER_Android_ 4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9192 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.4.7 Software version. Selected firmware file: I9192DDUAMJ2_I9192ODDAMJ2_INU_Android_ 4.2.2_provided_by_Palash_Ahammad_(aka_NP).oct Please put the phone into Download Mode and connect USB cable. To put GT-I9192 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.4.7 Software version. Selected firmware file: I9192UBUAMF7_ZTOAMF7_Brazil_Android_ 4.2.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9192 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.4.7 Software version. |
01-17-2017, 09:09 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload "*.log" and "*.logx" files of performed operations to any file-sharing service and post here download link. We will check where can be the problem with the phone. "*.log" and "*.logx" files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. Last edited by Octopus box; 01-17-2017 at 09:14. |
