12-20-2014, 03:29 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Rio de Janeiro - Brasil
Member: 797068 Status: Offline Thanks Meter: 75 | i9195 imei erro! ihow to resolve this error? Proper android device not [Solved] ----------------------------------------------------------------------------------- To connect GT-I9195 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Porto seleccionado: COM17 Modelo seleccionado: GT-I9195 Modo: Normal Modelo do telefone: GT-I9195 Data de criação do firmware: Apr 16 2014 Tiempo de criação do firmware: 03:00:00 Data de saída do firmware: Aug 26 2014 Tiempo de saída do firmware: 00:48:30 Versão do SW: M8930B-AAAATAZM-3.2.27080 IMEI antigo: 357432-05-010131-4 Novo IMEI: 357432-05-036772-5 Realizando o backup de NVM A leitura de NVM está terminada! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Last edited by Octopus box; 12-20-2014 at 06:46. |
