03-27-2015, 05:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | I9195 still not root after root success same use root file from support, also KingoRoot but i have to factory reset before using another root software Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-I9195 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM59 Selected model: GT-I9195 Mode: Normal Phone model: GT-I9195 Firmware compiled date: Jun 28 2013 Firmware compiled time: 00:00:00 Firmware released date: Dec 21 2013 Firmware released time: 02:51:05 Phone IMEI: 351886-06-374198-4 SW version: M8930B-AAAATAZM-3.2.27040 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM59 Selected model: GT-I9195 Mode: Normal Phone model: GT-I9195 Firmware compiled date: Jun 28 2013 Firmware compiled time: 00:00:00 Firmware released date: Dec 21 2013 Firmware released time: 02:51:05 Phone IMEI: 351886-06-374198-4 SW version: M8930B-AAAATAZM-3.2.27040 Unlocking phone... Creating NVM backup Reading NVM done! ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Sat Dec 21 01:46:00 KST 2013 PDA version: I9195XXUBML4 CSC version: I9195SFRBNA1 SW version: I9195XXUBML4 Phone IMEI: 351886063741984 Phone SN: R38F118BJSM Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM59 Selected model: GT-I9195 Mode: Normal Phone model: GT-I9195 Firmware compiled date: Jun 28 2013 Firmware compiled time: 00:00:00 Firmware released date: Dec 21 2013 Firmware released time: 02:51:05 Phone IMEI: 351886-06-374198-4 SW version: M8930B-AAAATAZM-3.2.27040 Unlocking phone... Creating NVM backup Reading NVM done! Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed |
03-27-2015, 20:20 | #4 (permalink) |
Junior Member Join Date: Jun 2011 Location: spain
Member: 1603312 Status: Offline Thanks Meter: 13 | I had the same problem, just try to write UPDATE-SuperSU-v1.65. zip via recovery, and then make unlock or imei with octopus, that works for me. |
The Following User Says Thank You to kokoroneko For This Useful Post: |
03-29-2015, 23:26 | #6 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | same try with CF-Auto-Root-serranolte-serranoltexx-gti9195 still not root run "SuperSU" and disable Knox and try unlock again but software detect that phone not rooted. thanks |
03-30-2015, 10:25 | #9 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2356158 Status: Offline Thanks Meter: 0 | here is the solution your firmware is 4.2.2 reflash it with 4.4.2 and try to root with odin again(CF-Auto-Root-serranolte-serranoltexx-gti9195) this root is supported by this version. |
03-31-2015, 14:44 | #10 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | try to flash with firmware 4.4.2 its failed i need help Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.5 ----------------------------------------------------------------------------------- To connect SGH-T399N phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect GT-I9195 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: PIT_I9195UBUAMF5_I9195CHEAMF5_Android_ 4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9195 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed Please put the phone into Download Mode and connect USB cable. To put GT-I9195 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed Please put the phone into Download Mode and connect USB cable. To put GT-I9195 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed Please put the phone into Download Mode and connect USB cable. To put GT-I9195 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed |
03-31-2015, 15:09 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Install the latest Software version. 2. Fully charge phone's battery by using external charger. 3. Connect the phone directly to PC motherboard USB port, don't use any USB hubs, this is important! 4. Try to write this firmware with PIT again. Try to write another firmware with PIT from the Support Area. Try to write firmwares without PIT. |
04-01-2015, 11:10 | #12 (permalink) |
Member: 2356158 Status: Offline Thanks Meter: 0 | your operator is claro it does not have 4.4.2 yet but reflash with I9195UBUCNG2 firmware 4.4.2 important try to use odin 3.9 v this time. just in case you suck in any step your original firmware is I9195UBUAMF5 4.2.2. |
