01-21-2015, 12:31 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: France Age: 34
Member: 2075792 Status: Offline Sonork: 14055112 Thanks Meter: 28 | i9195 write imei failed below is log please help Welcome to Octoplus/Octopus Box Samsung software version 1.8.1 ----------------------------------------------------------------------------------- To connect GT-I9195 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM231 Selected model: GT-I9195 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM230 Mode: Normal Phone model: GT-I9195 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM230 Selected model: GT-I9195 Mode: Normal Phone model: GT-I9195 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Old IMEI: Unknown New IMEI: 351533-06-507861-5 Creating NVM backup Reading NVM done! ADB server killed. Firmware compiled date: Sat Dec 21 01:46:00 KST 2013 PDA version: I9195XXUBML4 CSC version: I9195XEFBNA1 SW version: Unknown Phone IMEI: Unknown Android version: 4.2.2 (JDQ39) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9195-21-01-2015_12-28-09-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Found phone on COM230 Repairing NVM for GT-I9195 phone... Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM230 Selected model: GT-I9195 Mode: Normal Phone model: GT-I9195 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup thanks |
01-21-2015, 12:36 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
