01-25-2014, 11:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: tunisia
Member: 1874154 Status: Offline Thanks Meter: 18 | I9300 canot flash system I HAVE I9300 DEAD AFTER REPAIRED WITH CLIP I CANT FLASH IT STOP IN 2% SYSTEM Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing TZSW section... TZSW section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Last edited by princegsm1; 01-25-2014 at 12:00. |
01-25-2014, 12:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please fully charge phone's battery, connect the phone directly to motherboard USB port (don't use any USB hubs or PCI USB cards) and try to write firmware again. Try to use another Micro USB cable, try to write firmware on another PC, try to write different firmwares. If the problem will be still the same most likely, this is HW problem. |
