12-16-2013, 18:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 708514 Status: Offline Thanks Meter: 36 | I9300 cant write SYSTEM part !! ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. Selected firmware file: I9300XXELL5_I9300VFGELL2_SFR_Android_ 4.1.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SYSTEM section... Writing Firmware Failed |
12-16-2013, 18:53 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. What is the state of your device? What is the problem with your phone exactly? What is the firmware version in your phone now? |
12-17-2013, 09:39 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try also to write firmware by using original Samsung flasher. If the problem will be the same - most likely, this is HW problem. |
