08-13-2013, 19:22 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | I9300 flash Welcome to Octopus Box Samsung software version 1.9.4 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. Selected firmware file: I9300XXELLB_I9300OJVELL3_XFE_Android_4.1.1.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Please select firmware with PIT Writing Firmware Failed PLZ HOW CAN SOLVE THIS PROBLEME? |
08-14-2013, 06:35 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to write firmware with PIT ("PIT_I9300XXBLH1_I9300ITVBLH2") from the Support Area and post here the result. |
08-15-2013, 08:13 | #3 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | i av done it but still no ok To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. Selected firmware file: PIT_I9300XXBLH1_I9300ITVBLH2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed |
08-15-2013, 09:11 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to do the next: 1. Connect the device directly to motherboard USB port. 2. Try to connect your phone to USB hub with external power sypply. 3. Try on another PC. If the problem will be the same - most likely, this is HW problem (problem with flash chip). |
08-15-2013, 21:06 | #5 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: China
Member: 1919721 Status: Offline Thanks Meter: 10 | Tip Quote:
A) Reboot your cell phone into download mode than use RJ45 - MICRO UART cable and post results! IMPORTANT : ALWAYS BACKUP ( efs & full flash with octopus ) before the operation! | |
