04-01-2015, 15:07 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 441775 Status: Offline Thanks Meter: 22 | i9300 imei 00499 [Solved] can not rewrite the original imei phone I did all the steps. 1. Install the latest Software version (Software). 2. Make Repair EFS. 3. Re-flash the phone. 4. Make Factory data reset and wipe cache partition. 5. Root the phone. 6. Make Repair IMEI. To finish the "Repair IMEI" operation, restart the phone via phone's menu (via "Power on" button on the phone, don't disconnect the battery, this is important). 7. Write here the result. Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9300 Firmware compiled date: Tue May 21 18:14:15 KST 2013 PDA version: I9300XXUFME7 CSC version: I9300OXAFME7 SW version: I9300XXUFME7 Phone IMEI: 004999010640000 Phone SN: RF1C66BMMJY Android version: 4.2.2 (JDQ39) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\Secu rity-GT-I9300-Unknown01-04-2015_16-03-00-.asec file Cheking security type... Old security type is detected Old IMEI: 004999-01-064000-0 New IMEI: 358018-05-438674-3 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) imei always 004999-01-064000-0 Last edited by Octopus box; 04-03-2015 at 15:14. |
04-01-2015, 15:14 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Do the next: 1. Re-flash the phone. 2. Make Factory data reset and wipe cache partition. 3. Make Repair EFS. 4. Root the phone. 5. Make Repair IMEI. 6. Re-start the phone, check IMEI and say the result. |
04-01-2015, 15:50 | #5 (permalink) |
Member: 441775 Status: Offline Thanks Meter: 22 | --------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9300 Firmware compiled date: Tue Nov 26 17:03:22 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300ITVGMK1 SW version: Unknown Phone IMEI: Unknown Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 To put GT-I9300 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Tue Nov 26 17:03:22 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300ITVGMK1 SW version: I9300XXUGMK6 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.3 (JSS15J) Selected firmware file: Root_GT-I9300_4.3.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9300 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Tue Nov 26 17:03:22 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300ITVGMK1 SW version: I9300XXUGMK6 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9300 Firmware compiled date: Tue Nov 26 17:03:22 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300ITVGMK1 SW version: I9300XXUGMK6 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\Secu rity-GT-I9300-Unknown01-04-2015_16-45-10-.asec file Cheking security type... New security type is detected Old IMEI: 004999-01-064000-0 New IMEI: 351869-05-000004-4 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) imei null |
04-01-2015, 15:53 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to do the next: 1. Re-flash the phone to repair baseband. 2. Make Repair EFS. 3. Root the phone. 4. Write one of the Services IMEIs from the Software list. 5. Re-flash the phoen again. 6. Check IMEI. 7. Post here full Software log with all of these actions and say the result. Also, root the phone, select GT-I9500 model in the Software list, select (mark) "Manual select" option in the Software and try to write IMEI Certificate from the Support Area. If the problem is the same, most likely, your device has HW issue. Last edited by Octopus box; 04-01-2015 at 16:31. |
04-01-2015, 16:18 | #7 (permalink) |
No Life Poster Join Date: Apr 2012 Location: < Man is stronger than stone.>
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | Try write modem part,to get into any imei. My opinion,why are giving wrong details of imei and serial,probably changed lcd with other imei on it. All the best |
04-01-2015, 16:35 | #9 (permalink) |
Member: 441775 Status: Offline Thanks Meter: 22 | no, did the whole procedure, written with 4 firmware boot file, pda, csc ect .. imei 00499 modem ok,, written imei imei original file in the list and always result imei 00499 Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 To put GT-I9300 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 26 15:44:21 KST 2012 PDA version: I9300XXELLB CSC version: I9300OJVELL3 SW version: I9300XXELLA Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Wed Dec 26 15:44:21 KST 2012 PDA version: I9300XXELLB CSC version: I9300OJVELL3 SW version: I9300XXELLA Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\Secu rity-GT-I9300-Unknown01-04-2015_17-25-39-.asec file Cheking security type... Old security type is detected Old IMEI: 004999-01-064000-0 New IMEI: 351869-05-000011-9 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Wed Dec 26 15:44:21 KST 2012 PDA version: I9300XXELLB CSC version: I9300OJVELL3 SW version: I9300XXELLA Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\Secu rity-GT-I9300-Unknown01-04-2015_17-31-52-.asec file Cheking security type... Old security type is detected Old IMEI: 004999-01-064000-0 New IMEI: 358018-05-438674-3 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
04-01-2015, 16:37 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Root the phone, select GT-I9500 model in the Software list, select (mark) "Manual select" option in the Software and try to write IMEI Certificate from the Support Area. If the problem is the same, most likely, your device has HW issue. |
04-01-2015, 17:48 | #13 (permalink) |
Member: 441775 Status: Offline Thanks Meter: 22 | To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9500 Selected file: G:\FIRMWARE SAMSUNG\S3\GT-I9300_354017054332123_RV1CA39PQX.cert Detected phone model: GT-I9300 Firmware compiled date: Wed Dec 26 15:44:21 KST 2012 PDA version: I9300XXELLB CSC version: I9300OJVELL3 SW version: I9300XXELLA Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is correct Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes imei 00499... |
04-01-2015, 18:07 | #14 (permalink) | |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Quote:
bro......flash 4.3 ver & test write cert again. BR Nizda Mobile | |
The Following User Says Thank You to Nizda Mobile For This Useful Post: |
