Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 09-27-2012, 17:49   #16 (permalink)
ZiDanRO's Avatar
Member: 1722871
Originally Posted by rumenshom View Post
"it shows unknown"
regards
Please read this I9300 IMEI repair OK but NO signal
It will solve your mistery. You need to open the phone and if ther is no antena is a demo unit.
Old 09-28-2012, 06:04   #17 (permalink)
rumenshom's Avatar
Member: 899774
Sonork: 100.1586303
without disassemble how to know is it demo or not?
Old 09-28-2012, 06:12   #18 (permalink)
ZiDanRO's Avatar
Member: 1722871
It is not hard to open the phone. It easy very very very easy and fast. Only 4-5 screws and no clips.
Other way to check but no 100% sure is if on the gsm signal you have a cross circle. This is becouse you don't have the antena.
The Following User Says Thank You to ZiDanRO For This Useful Post:
Old 09-28-2012, 06:15   #19 (permalink)
rumenshom's Avatar
Member: 899774
Sonork: 100.1586303
@ZiDanRO
but customer wanna want to do that.
Old 09-28-2012, 06:38   #20 (permalink)
ZiDanRO's Avatar
Member: 1722871
@ZiDanRO
What dose he whant? To not open the phone?
If he don't whant to open then phone. Only the gsm signal is the clue:
- if it looks like this, it has GSM module http://www.google.com/imgres?q=gsm+s...9,r:2,s:0,i:75
- if it looks like this, it dosen't have GSM module: http://www.google.com/imgres?q=no+st...:11,s:43,i:243
Old 10-03-2012, 16:18   #21 (permalink)
Member: 1258305
My Expiriance afther repair imei i didnt have network but i go manualy to search network afther 2-3 mins of search i got a network so do the same.Afther unlock and imei repair put sim in whatever sim you want and search maunaly the network afther 2-3 mins maybe more, maybe less your phone will find the network.I tested that on 10 phones i9300 with android 4.0.4 inside.
Regards,
LiLSaint
The Following 2 Users Say Thank You to LiLSaint For This Useful Post:
Old 10-24-2012, 11:46   #22 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
I M FACING ANOTHER PROBLEM I HAVE RECIVE A I9300 WITHOUT BACK LABLE AND SET IMEI 0049XXXXXX AND SN:0000000000 SO ITS DIFICULT TO FIND ITS ORIGNAL IMEI I HAVE WRITE ANOTHER I9300 IMEI AND SN: I HAVE TAKE IMEI AND SN: TO A FRIEND FROM OTHER COUNTRY .
I REPAIR EFS AND WRITE IMEI AND SN: BUT STILL SAME THEN I FLASH WITH ANOTHER FRIMWARE STILL SAME ...... MY QUSTION IS .... IS POSIBAL TO WRITE IMEI FROM ANOTHER I9300 .....???? AN OTHER WORDS ITS POSIBAL TO CHANGE IMEI IN I9300 WITH OCTOPUS???? HERE IS LOG
Welcome to Octopus Box Samsung software version 1.6.5
To connect GT-I9300 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Reboot phone.
10. Press "Read Info" in Octopus Samsung software.
Platform: Samsung Android
Selected port: COM87
Selected model: GT-I9300
Searching for a phone. Please wait...
Phone found.
Firmware compiled date: Sun May 13 06:50:29 KST 2012
Android version: 4.0.4 (IMM76D)
Old IMEI: Unknown
New IMEI: 358001-04XXXXX52-8
Erasing old IMEI. It can take some time. Please wait...
Creating NVM backup
Backup saved as C:\Program Files\GsmServer\OctopusSamsung
\BACKUP\NVDATA-GT-I9300-24-10-2012_15-32-24-.nvm file
Old IMEI was erased successfully.
Phone will restart now
After phone being rebooted and powered on perform the following
steps:
1. Disconnect USB cable.
2. Go to dial window.
3. Enter *#9090# number.
4. Set speed to 115200.
5. Connect phone via UART cable to Box.
Connecting to phone, please wait...
Phone connected successfully
Deactivating MSL...
MSL deactivate successfully
Please conect phone to USB cable
Phone found.
Writing security protection...
Security protection write successfully.
Phone found.
Writing new phone IMEI...
New IMEI successfully written.
Please, restart the phone to apply changes
Old 10-24-2012, 12:08   #23 (permalink)
ZiDanRO's Avatar
Member: 1722871
It is posible but if you have a working phone, not a live demo unit. Search the forum if you don't know what it is.
If it is a working phone, after writing the IMEI it will work.
Old 10-24-2012, 15:28   #24 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
Originally Posted by zidanro View Post
it is posible but if you have a working phone, not a live demo unit. Search the forum if you don't know what it is.
If it is a working phone, after writing the imei it will work.
yes dear its demo unit i have confrm now before custmer noT aloow me to deasaamble tha unit... But now afetr alow to custmr i have confrm it . There is no any gsm parts and antena inside
thanx a lot bro
Old 11-07-2012, 11:02   #25 (permalink)
Member: 782637
does anyone know to to fix it without using uart cable?????
Old 11-07-2012, 12:28   #26 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Currently no such (without using uart cable) solution.
Old 01-28-2013, 15:02   #27 (permalink)
Member: 1249391
Thanks bros
Thanks, the v1.7.7 works well for the network problem after imei repairs for samsung I9300.
Appreciate the help of Octpus team.
the new update can fix network problem after imei repair.
tested. 100000000000% working
McBen
Originally Posted by Octopus box View Post
@ rumenshom
Please contact us, we will try to help You remotely via Team Viewer.
Old 01-29-2013, 16:50   #28 (permalink)
Member: 1831560
imei repaired successfully but no service.
i did
flsh with different version
repair efs
root
but still no service.
is there any solution for this?
regards
I had the same issue,.
you just have to perform a hard reset from the the phone, don't use the buttons combination to do the hard reset
Old 01-29-2013, 17:09   #29 (permalink)
Member: 1831560
9. Reboot phone.
Phone found.
Old IMEI: Unknown
Creating NVM backup
steps:
Deactivating MSL...
Phone found.
Phone found.
Yes, it is possible to change the imei on the i9300 using Octopus box, but you you need to make sure that all dirvers are installed correctly.
try the following.
1. on keypad dial *#7284#, hit Qualcomm SUB settings and chose DM + MODEM + ADB
2. dial *#9090#, chose USB
3. connect the phone to the pc and wait for the computer to install drivers, reboot the phone after its done with installing the drivers
4. finally try again with octopus software to change the imei
* make sure to write the right imei and only change the last 1 number of that imei *
Page generated in 0.41619 seconds with 10 queries
