01-18-2014, 22:04 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | I9300 problem flashing ----------------------------------------------------------------------------- To connect GT-S5830 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... Phone found. Repair EFS failed ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... Phone found. Repair EFS failed Selected firmware file: I9300XXEMC2_I9300YOGEMD1 _I9300XXEMC2_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Please select firmware with PIT Writing Firmware Failed Selected firmware file: PIT_I9300XXBLH1_I9300ITVBLH2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed first problem PIT after put flash with PIT writing firmware failed waiting answer |
01-19-2014, 09:58 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please fully charge phone's battery and repeat the operation once again. Also try to connect the device to another motherboard USB ports, don't use any USB hubs or USB PCI cards. Try to perform the operation on another PC. If the problem will be the same - most likely, this is HW problem. |
01-19-2014, 20:43 | #3 (permalink) |
Member: 39250 Status: Offline Thanks Meter: 64 | battery is full charged it not a first i have many phone after boot repair only give error PIT, i open other post with N7100 problem error is some |
