12-28-2013, 01:32 | #1 (permalink) |
Crazy Poster Join Date: Jun 2013
Member: 1957672 Status: Offline Thanks Meter: 11 | i9300 up to 4.2.2 but emergency call only fix by repaire network ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Mon Mar 11 18:27:09 KST 2013 PDA Version: I9300ZSEMC1 CSC Version: I9300OZSEMC1 SW Version: I9300XXELLA Phone IMEI: 353742050203439 Phone SN: R21C63NM11Y Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Reading EFS, please wait... EFS read successfully. Selected firmware file: I9300XXUFME7_I9300OXAFME7_I9300XXUFME7 _HOME_4.2.2.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing TZSW section... TZSW section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Repairing network failed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Tue May 21 18:14:15 KST 2013 PDA Version: I9300XXUFME7 CSC Version: I9300OXAFME7 SW Version: I9300XXUFME7 Phone IMEI: 353742050203439 Phone SN: R21C63NM11Y Android version: 4.2.2 (JDQ39) Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Phone will restart now Network is successfully repaired. |
The Following User Says Thank You to l.panha For This Useful Post: |
