02-06-2015, 18:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1865815 Status: Offline Sonork: 100.1644854 Thanks Meter: 25 | i9300i no signal |
02-07-2015, 01:23 | #3 (permalink) |
Member: 1865815 Status: Offline Sonork: 100.1644854 Thanks Meter: 25 | Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\03-02-2015_15-44-17.log" created (03/02/2015 03:44:19 p.m.). ERROR : 03/02/2015 03:44:20 p.m. > Access violation at address 0094495C in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 03/02/2015 03:44:21 p.m. > Set up system language Spanish (file: Spanish.ini) INFO : 03/02/2015 03:44:21 p.m. > Welcome to Octoplus/Octopus Box Samsung software version 1.8.3 INFO : 03/02/2015 03:44:21 p.m. > ----------------------------------------------------------------------------------- INFO : 03/02/2015 03:44:21 p.m. > To connect GT-I9195 phone you have to perform the following steps: INFO : 03/02/2015 03:44:21 p.m. > 1. Disconnect USB cable from phone. INFO : 03/02/2015 03:44:21 p.m. > 2. Go to Menu->Settings->More->About Device. INFO : 03/02/2015 03:44:21 p.m. > 3.Tap on "Build number" 7 times to enable developer options. INFO : 03/02/2015 03:44:21 p.m. > 4. Go to Menu->Settings->More->Developer options. INFO : 03/02/2015 03:44:21 p.m. > 5. Turn on "USB Debugging" option. INFO : 03/02/2015 03:44:21 p.m. > 6. Go to dial window. INFO : 03/02/2015 03:44:21 p.m. > 7. Enter "*#0808#" number. INFO : 03/02/2015 03:44:21 p.m. > 8. Select "DM+Modem+ADB". INFO : 03/02/2015 03:44:21 p.m. > 9. Press Home button. INFO : 03/02/2015 03:44:21 p.m. > 10. Go to dial window. INFO : 03/02/2015 03:44:21 p.m. > 11. Enter "*#9090#" number. INFO : 03/02/2015 03:44:21 p.m. > 12. Set "Diag config" to "USB" value. INFO : 03/02/2015 03:44:21 p.m. > 13. Restart phone. INFO : 03/02/2015 03:44:21 p.m. > 14. Press "Read Info" in software. INFO : 03/02/2015 03:44:41 p.m. > ----------------------------------------------------------------------------------- INFO : 03/02/2015 03:44:41 p.m. > To connect GT-I9300I phone you have to perform the following steps: INFO : 03/02/2015 03:44:41 p.m. > 1. Disconnect USB cable from phone. INFO : 03/02/2015 03:44:41 p.m. > 2. Go to Menu->Settings->More->About Device. INFO : 03/02/2015 03:44:41 p.m. > 3.Tap on "Build number" 7 times to enable developer options. INFO : 03/02/2015 03:44:41 p.m. > 4. Go to Menu->Settings->More->Developer options. INFO : 03/02/2015 03:44:41 p.m. > 5. Turn on "USB Debugging" option. INFO : 03/02/2015 03:44:41 p.m. > 6. Go to dial window. INFO : 03/02/2015 03:44:41 p.m. > 7. Enter "*#0808#" number. INFO : 03/02/2015 03:44:41 p.m. > 8. Select "DM+Modem+ADB". INFO : 03/02/2015 03:44:41 p.m. > 9. Press Home button. INFO : 03/02/2015 03:44:41 p.m. > 10. Go to dial window. INFO : 03/02/2015 03:44:41 p.m. > 11. Enter "*#9090#" number. INFO : 03/02/2015 03:44:41 p.m. > 12. Set "Diag config" to "USB" value. INFO : 03/02/2015 03:44:41 p.m. > 13. Restart phone. INFO : 03/02/2015 03:44:41 p.m. > 14. Press "Read Info" in software. INFO : 03/02/2015 03:45:55 p.m. > ----------------------------------------------------------------------------------- INFO : 03/02/2015 03:45:56 p.m. > Platform: Samsung Android INFO : 03/02/2015 03:46:00 p.m. > Selected port: COM126 INFO : 03/02/2015 03:46:00 p.m. > Selected model: GT-I9300I INFO : 03/02/2015 03:46:01 p.m. > Mode: Normal INFO : 03/02/2015 03:46:01 p.m. > Phone model: GT-I9300I INFO : 03/02/2015 03:46:01 p.m. > Firmware compiled date: Dec 11 2013 INFO : 03/02/2015 03:46:01 p.m. > Firmware compiled time: 02:00:00 INFO : 03/02/2015 03:46:01 p.m. > Firmware released date: Mar 31 2014 INFO : 03/02/2015 03:46:01 p.m. > Firmware released time: 15:40:48 INFO : 03/02/2015 03:46:01 p.m. > Phone IMEI: 352607-06-013755-7 INFO : 03/02/2015 03:46:01 p.m. > SW version: M8626A-AAAANAZM-1.0.4016 INFO : 03/02/2015 03:46:22 p.m. > ----------------------------------------------------------------------------------- INFO : 03/02/2015 03:46:23 p.m. > Platform: Samsung Android INFO : 03/02/2015 03:46:23 p.m. > Selected port: COM126 INFO : 03/02/2015 03:46:24 p.m. > Selected model: GT-I9300I ERROR : 03/02/2015 03:46:25 p.m. > Please select service IMEI for this phone model ERROR : 03/02/2015 03:46:25 p.m. > Please select service IMEI for this phone model INFO : 03/02/2015 03:46:29 p.m. > Detected phone model: GT-I9300I INFO : 03/02/2015 03:46:29 p.m. > Firmware compiled date: Tue Apr 1 14:33:15 KST 2014 INFO : 03/02/2015 03:46:29 p.m. > PDA version: I9300IUBUAND1 INFO : 03/02/2015 03:46:30 p.m. > CSC version: I9300IUUBAND1 INFO : 03/02/2015 03:46:30 p.m. > SW version: I9300IUBUAND1 INFO : 03/02/2015 03:46:31 p.m. > Phone IMEI: 352607060137557 INFO : 03/02/2015 03:46:32 p.m. > Phone SN: RF1F50K210F INFO : 03/02/2015 03:46:32 p.m. > Android version: 4.3 (JLS36C) INFO : 03/02/2015 03:46:32 p.m. > Cheking Root INFO : 03/02/2015 03:46:33 p.m. > Phone is Rooted INFO : 03/02/2015 03:46:33 p.m. > Reading security backup, please wait... INFO : 03/02/2015 03:46:53 p.m. > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9300I-352607060137557-03-02-2015_15-46-33-.asec file INFO : 03/02/2015 03:46:53 p.m. > Deactivating MSL... INFO : 03/02/2015 03:47:13 p.m. > MSL deactivate successfully WARN : 03/02/2015 03:47:15 p.m. > Phone will restart now. Please don't disconnect cable! WARN : 03/02/2015 03:48:05 p.m. > After phone being rebooted and powered on perform the following steps: WARN : 03/02/2015 03:48:05 p.m. > 1. Disconnect USB cable. WARN : 03/02/2015 03:48:05 p.m. > 2. Wait for 1-2 minutes. WARN : 03/02/2015 03:48:05 p.m. > 3. Connect phone via UART cable to the Box. WARN : 03/02/2015 03:48:05 p.m. > 4. Note: phone screen must be active INFO : 03/02/2015 03:48:05 p.m. > Connecting to phone, please wait... INFO : 03/02/2015 03:48:10 p.m. > Found phone on COM48 INFO : 03/02/2015 03:48:10 p.m. > Phone connected successfully INFO : 03/02/2015 03:48:11 p.m. > Writing new phone IMEI... INFO : 03/02/2015 03:48:47 p.m. > IMEI successfully repaired. WARN : 03/02/2015 03:48:47 p.m. > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) INFO : 03/02/2015 03:56:45 p.m. > ----------------------------------------------------------------------------------- INFO : 03/02/2015 03:57:01 p.m. > Platform: Samsung Android INFO : 03/02/2015 03:57:03 p.m. > Selected port: COM126 INFO : 03/02/2015 03:57:03 p.m. > Selected model: GT-I9300I INFO : 03/02/2015 03:57:04 p.m. > Mode: Normal INFO : 03/02/2015 03:57:04 p.m. > Phone model: GT-I9300I INFO : 03/02/2015 03:57:04 p.m. > Firmware compiled date: Dec 11 2013 INFO : 03/02/2015 03:57:04 p.m. > Firmware compiled time: 02:00:00 INFO : 03/02/2015 03:57:04 p.m. > Firmware released date: Mar 31 2014 INFO : 03/02/2015 03:57:04 p.m. > Firmware released time: 15:40:48 INFO : 03/02/2015 03:57:04 p.m. > Phone IMEI: 352602-05-434067-1 INFO : 03/02/2015 03:57:04 p.m. > SW version: M8626A-AAAANAZM-1.0.4016 INFO : 03/02/2015 03:57:04 p.m. > Repairing 3G/4G... INFO : 03/02/2015 03:57:04 p.m. > Reading nv... INFO : 03/02/2015 03:57:10 p.m. > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NV-GT-I9300I-352602054340671-03-02-2015_15-57-04-.nv file INFO : 03/02/2015 03:57:18 p.m. > 3G/4G repair successfully WARN : 03/02/2015 03:57:18 p.m. > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\03-02-2015_15-44-17.log" closed (03/02/2015 03:58:09 p.m.). |
02-07-2015, 09:22 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to make Repair of both IMEIs (write service's IMEIs from the Software list, not any IMEIs), then write this QCN: https://mega.co.nz/#!SkwUBLaT!C_MxtO...8rU38ZpBkwf26s, restart the phone, insert SIM card, wait 5-7 minutes and try to find and select network manually. |
06-25-2015, 19:35 | #5 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | Quote:
