02-20-2016, 14:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | i9300i virus problem [Solved] i just downloaded firmware trying to flash 1st. Last edited by Octopus box; 02-22-2016 at 10:56. |
02-20-2016, 17:09 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Please make Factory Reset and Wipe cache partition from Recovery Mode, then try to reflash the phone with "i9300ixxubnh3_i9300ioxebnh3_skz_kazachstan_androi d_4.4.4" firmware from the Support Area. Post here full Software log of "Write Firmware" operation. |
02-20-2016, 18:16 | #7 (permalink) |
Member: 199814 Status: Offline Thanks Meter: 1,960 | the phone showing i9300i in download mode and from about info showing i9301 so flashed with i9301 firmware and it worked to flash. still infected with virus. now i have used to hard reset, clear cache / wipe factory data. and flashed again. and wipe + clear cache again. let me see what happened now. |
02-20-2016, 18:39 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | If after writing of a firmware followed by Factory Reset problem remains the same - unfortunately no solution for it at the moment. |
02-21-2016, 07:16 | #13 (permalink) |
Member: 199814 Status: Offline Thanks Meter: 1,960 | i flashed with custom recovery and wiped every thing but still same . now trying to write customized firmware on it. and a custom firmware helped me to fix it up. thanks team Last edited by Octopus box; 02-22-2016 at 10:55. |
02-21-2016, 19:57 | #14 (permalink) |
Insane Poster Join Date: Oct 2013 Location: Turkmenistan, Balkanabat
Member: 2044809 Status: Offline Thanks Meter: 11 | Virus problem can fix by install working antivirus (i use kaspersky) and then make full scan or if first step not help just flash with service multi file firmware WORK 100% |
