12-10-2014, 21:07 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | I9301I Problem unlock i need try 3 4 5 times to unlock 1 s3 neo please fix this bugs and sometime after change imei , imei not changed so i need to try 2 time to change it pleaseee fix this error |
12-10-2014, 21:58 | #4 (permalink) |
Member: 39250 Status: Offline Thanks Meter: 64 | other problem Platform: Samsung Android Selected port: COM2261 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9301I Firmware compiled date: Tue Aug 12 16:25:56 KST 2014 PDA version: I9301IXXUANH1 CSC version: I9301IXEOANF1 SW version: I9301IXXUANF2 Phone IMEI: 356650068785007 Phone SN: RV1FB0KWRVY Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus \Octoplus_Samsung\BACKUP\Security-GT-I9301I- 356650068785007-10-12-2014_20-35-27-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM5 Phone connected successfully Writing new phone IMEI... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM2265 Selected model: GT-I9301I Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM2264 Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: Jun 19 2014 Firmware released time: 19:15:09 Phone IMEI: 356650-06-878500-7 SW version: M8626A-AAAANAZM-1.0.4050 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files (x86)\Octoplus \Octoplus_Samsung\BACKUP\NV-GT-I9301I-356650068785007-10- 12-2014_20-41-41-.nv file Writing NVM canceled 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM2264 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM2264 Selected model: GT-I9301I Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9301I Firmware compiled date: Tue Aug 12 16:25:56 KST 2014 PDA version: I9301IXXUANH1 CSC version: I9301IXEOANF1 SW version: I9301IXXUANF2 Phone IMEI: 356650068785007 Phone SN: RV1FB0KWRVY Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus \Octoplus_Samsung\BACKUP\Security-GT-I9301I- 356650068785007-10-12-2014_20-42-01-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM5 Phone connected successfully Writing new phone IMEI... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM2264 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: Jun 19 2014 Firmware released time: 19:15:09 Phone IMEI: 352608-06-013755-5 SW version: M8626A-AAAANAZM-1.0.4050 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files (x86)\Octoplus \Octoplus_Samsung\BACKUP\NV-GT-I9301I-352608060137555-10- 12-2014_20-48-05-.nv file 3G/4G repair successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) imei no changed at the first , changed in the second attempt Last edited by flechazo; 12-10-2014 at 22:05. |
12-10-2014, 21:58 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | From your first post follows that error appears not during every operation. Under which conditions it appears exactly and what is exact text of this error? Try to restart the PC, close all third-party Software and do exactly the next: 1. Write firmware "I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6_HOM E" from the Support Area. 2. Re-start the phone. 3. Root the phone by using TowelRoot. 4. Write the second service's IMEI from the Software list (not any IMEI). 5. Make Repair 3G/4G. 6. Restart the phone. 7. Write the first NVM backup (that You or Software created before first "Unlock" or "Repair IMEI" operation) or try to write this NVM backup https://mega.co.nz/#!X4YDFaAI!w_ZQUT...Rh7QvZxtt9znqA. 8. Post here full Software log with all of these actions. |
12-10-2014, 22:08 | #6 (permalink) |
Member: 39250 Status: Offline Thanks Meter: 64 | but why appears this error and software is blocked? other picture desactivating MSL after 10min still desactivating MSL NO ANSWER U UNDERSTAND BRO? Last edited by Octopus box; 12-11-2014 at 12:23. |
12-11-2014, 12:23 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
12-11-2014, 14:09 | #8 (permalink) |
Member: 39250 Status: Offline Thanks Meter: 64 | is not problem pc bro , what about other error desactivating MSL after 10min still desactivating MSL NO ANSWER and imei no changed at the first unlock ??? |
12-11-2014, 14:38 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do exactly all the next steps: 1. Close the Software. 2. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 3. Take out SIM and SD cards from the phone. 4. Disconnect all other devices from the PC. 5. Run the Software. 5. Write firmware "I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6_HOM E" from the Support Area. 6. Re-start the phone. 7. Root the phone by using TowelRoot. 8. Write the second service's IMEI from the Software list (not any IMEI). 9. Make Repair 3G/4G. 10. Close the Software. 11. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the links, we will research where can be the problem with your device and say You the result. |
12-11-2014, 14:50 | #10 (permalink) |
Member: 39250 Status: Offline Thanks Meter: 64 | bro i unlock more than 300 Pcs i9301i if u dont have any solution to fix this error dont give m manual to unlock it because i now all this , log and picture sended all is clear THIS IS PROBLEM SOFTWARE |
12-11-2014, 14:58 | #11 (permalink) | |
