01-17-2014, 13:02 | #1 (permalink) |
Banned Join Date: May 2006 Location: france
Member: 270730 Status: Offline Thanks Meter: 67 | i9305 4.1.2 not unlocked? Welcome to Octoplus/Octopus Box Samsung software version 1.4.5 ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- . ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: GT-I9305 Mode: Normal Phone model: GT-I9305 Firmware compiled date: Oct 16 2012 Firmware compiled time: 05:00:00 Firmware released date: Dec 12 2012 Firmware released time: 17:19:49 Phone IMEI: 35357....... SW version: M9615ACEHWMAZD179590 Unlocking phone... Phone unlocking failed |
01-17-2014, 14:39 | #3 (permalink) |
Member: 270730 Status: Offline Thanks Meter: 67 | phone is rooted with octopus root ? Welcome to Octoplus/Octopus Box Samsung software version 1.4.5 ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. Selected firmware file: Root_GT-I9305.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9305 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Firmware writing successfully completed. |
01-17-2014, 14:56 | #4 (permalink) |
Member: 270730 Status: Offline Thanks Meter: 67 | Platform: Samsung Android Selected port: COM23 Selected model: GT-I9305 Mode: Normal Phone model: GT-I9305 Firmware compiled date: Oct 16 2012 Firmware compiled time: 05:00:00 Firmware released date: Dec 12 2012 Firmware released time: 17:19:49 Phone IMEI: 353575-05-893695-0 SW version: M9615ACEHWMAZD179590 Unlocking phone... Phone unlocking failed |
01-17-2014, 15:10 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Most likely, there is new (currently not supported) security type in your device. Please re-flash the phone with the firmware from the Support Area and try to perform "Unlock" operation once again. |
01-17-2014, 16:39 | #6 (permalink) |
Member: 270730 Status: Offline Thanks Meter: 67 | after flash with support :K:\box de deblocage\octopus\I9305XXALK3_I9305BOGALJ3_BOG\I93 05XXALK3_I9305BOGALJ3_BOG.oct Platform: Samsung Android Selected port: COM23 Selected model: GT-I9305 Mode: Normal Phone model: GT-I9305 Firmware compiled date: Sep 12 2012 Firmware compiled time: 13:00:00 Firmware released date: Nov 6 2012 Firmware released time: 13:04:35 Phone IMEI: 353575-05-893695-0 SW version: M9615ACEHWMAZD179545 Unlocking phone... Phone unlocking failed |
01-17-2014, 17:03 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | As I have said above, most likely, there is new (currently not supported) security type in your device. Please do the next: 1. Root your device. 2. Select "GT-I9505" in devices list. 3. Connect the device via Micro USB cable and turn on "USB Debugging" Mode. 4. Select (check) "Manual select" option in Software. 5. Make backup EFS ("Read EFS" button). 6. Make backup Security ("Read Security" button). 7. Upload somewhere these backups and post here links, we will research the problem and try to prepare test Software version for You. |
