04-20-2016, 11:33 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try to make Factory Reset and Wipe cache partition from Recovery Mode, then reflash the phone. If problem will remain - try to make "Repair EFS" operation. Note: phone's IMEI might be reset to default value. |
04-20-2016, 11:35 | #3 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
Factory Reset and Wipe cache partition same problem | |
04-20-2016, 12:52 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please do exactly the next: 1. Relfash the phone with "I9305XXUFPB1_I9305NEEFPB1_NEE_Android_4.4.4" firmware from the Support Area. 2. Perform "Repair EFS" operation. Check whether phone powers on correctly after these actions. Post here result and full Software log of these actions. |
04-22-2016, 11:58 | #9 (permalink) | |
To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. Selected firmware file: I9305XXUFPB1_I9305NEEFPB1_NEE_Android_ 4.4.4.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9305 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing TZSW section... TZSW section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9305 To put GT-I9305 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully Performed by 2.2.4 software version logo only hard reset same | |
