Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 10-04-2014, 10:04   #16 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
before i repair imei it's not null, it's 0049xxx then after repair imei it goes null, even i write the efs back up or repair still null
This means your device has new PCU Bootrom. You need to write one of the service's IMEIs from the Software list and then re-flash the phone. Look here: http://forum.gsmhosting.com/vbb/f684...i9500-1751585/.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 10-04-2014, 10:10   #17 (permalink)
Member: 1146942
Sonork: 100.1587278
Can i remove battery??? The phone again will go to download mode?
Yes, remove the battery, charge phone's battery by using external charger and try to write firmware again. Try to write other firmwares. If the problem is the same - check phone's HW (most likely, the problem is with phone's eMMC flash chip).
Old 10-04-2014, 10:13   #18 (permalink)
omi17's Avatar
Member: 1950912
Sonork: 100.1654643(Offline)
Thanks Meter: 403
Smile
Originally Posted by Octopus box View Post
Yes, remove the battery, charge phone's battery by using external charger and try to write firmware again. Try to write other firmwares. If the problem is the same - check phone's HW (most likley, the problem is with phone's eMMC flash chip).
I removed battery yepp phone is still going to download mode but showing "system status : custom".
Now Downloading this file "I9500XXUFNG1_I9500ODDFNE1_SLK_Android_4.4.2"
I will post result asap
Old 10-04-2014, 10:26   #19 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
yes remove battery and reinsert
flash with other version
Old 10-06-2014, 07:23   #20 (permalink)
Member: 736901
Thanks Meter: 15
i recover the imei by repair security, how can repair the imei to have a fully network
Welcome to Octoplus/Octopus Box Samsung software version 1.6.8
To connect GT-I9500 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Platform: Samsung Android
Selected port: COM21
Selected model: GT-I9500
Reading info, please wait...
Detected phone model: GT-I9500
Firmware compiled date: Wed May 28 23:23:46 KST 2014
PDA version: I9500XXUFNE7
CSC version: I9500OJVFNF1
SW version: Unknown
Phone IMEI: Unknown
Android version: 4.4.2 (KOT49H)
SW version: Unknown
Phone IMEI: Unknown
Repairing network. Please wait, this can take some time...
Phone will restart now
SW version: Unknown
Phone IMEI: Unknown
SW version: Unknown
Phone IMEI: Unknown
SW version: I9500XXUFNC1
Phone IMEI: 004999010640000
Phone SN: RF1F70A6Z0J
Old 10-06-2014, 07:52   #21 (permalink)
Member: 1146942
Sonork: 100.1587278
Do exactly the next:
1. Make Repair EFS.
2. Re-flash the phone again.
3. Make Repair IMEI (write one of the servcies IMEIs from the Software list, not any IMEI).
4. Re-flash the phone again.
Old 10-23-2014, 19:28   #22 (permalink)
Member: 808967
Thanks Meter: 155
Plataforma: Samsung Android
Puerto seleccionado: COM240
Modelo seleccionado: GT-I9500
Modelo del teléfono detectado: GT-I9500
Fecha de creación del firmware: Mon Feb 24 20:49:11 KST 2014
PDA version: I9500ZSUDNB3
CSC version: I9500OZSDNB3
Versión del SW: Unknown
IMEI del teléfono: Unknown
Reading security backup, please wait...
Backup saved as C:\Archivos de programa\Octoplus
\Octoplus_Samsung\BACKUP\Security-GT-I9500-Desconocido23-10-
2014_13-24-35-.asec file
Cheking security type...
Old security type is detected
Executing exploit...
Write IMEI failed
El teléfono se reiniciará ahora
team try to get right imei null null makes the whole process and nothing remains imei null null
Old 10-23-2014, 19:37   #23 (permalink)
Member: 1146942
Sonork: 100.1587278
As You can see from your Software log, phone's modem part is damaged:
SW version: Unknown
This can be Software (modem firmware is damaged or You have written unsuitable firmware) or HW problem.
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown).
If phone's IMEI becomes null after "Repair IMEI operation" - your device has new PCU Bootrom. You need to write one of the service's IMEIs from the Software list and then re-flash the phone. Look here: http://forum.gsmhosting.com/vbb/f684...i9500-1751585/
Page generated in 0.17821 seconds with 8 queries
